turbo enthusiast
Picked up a '69 C30 motorhome with the stock 16'' split rims. The tires are bad but I have some good 16'' tires on wheels off of a late '80s Furd motorhome. I know you guys say to junk the split rims, but will the Furd wheels fit on my all drum '69 C30? I don't have the money for new wheels.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
its all about the +6 inches
Re: another wheel question on a C30
the problem with this, is they will be putting all the weight on the lugs... and not on the hub. This often leads to broken studs and worst case scenereo... wheels coming off.
Now, this doesn't matter NEARLY as much in a 1/2 ton that never gets worked... but a motor home is loaded down pretty good already, so it matters. |
turbo enthusiast
so I can't use the furd rims and nobody will touch the split rims, what wheels do I need to get? Preferably used but I want to be safe. Mid 70's chevy duallies, maybe? Just figured the disc brake front end on them might require a different wheel then what I need. Or just take the whole front cross member off a mid 70's dually, then I'll have the disc brakes for my motorhome and the wheels I need! Yah, wish I had that kind of money.
I'm 99% positive that any GM daulie wheel will slip right on. The studs are bigger on the 71 and later ones, but the taper is the same and I've never had an issue with that. (both my old longhorn, and current longhorn had later wheels with the 9/16 lug hole instead of the 1/2 inch hole like the 70 and older are supposed to have)
![]() Join Date: Apr 2007
My 72 c20 has dual wheels on the back with 9/16 studs and the wheels are 16'' tubeless that I ran on my 87 G 30 box truck and are the same as the wheels on my newer 2001 3500 box truck. hope that helps!
