Old 05-16-2007, 08:02 PM   #1
mothertrucker424
mothertrucker424's Avatar
tires/lift
i have a 4" lift on my 72' k10 i have 33's and they look to small i want to run 36" iroks is this to large or do i need more lift i plan on stuffing them and lifting more in future too
if i add 3/4 ton leafs (rear) to my 1/2 ton will that boost it or is that not even enough to waste my time
and does anyone run iroks??
mothertrucker424 is offline   Reply With Quote
Old 05-16-2007, 08:21 PM   #2
1969k10stepside
Re: tires/lift
36s probably wont fit under it without rubbing while it just sits there.That was just about the way my 71 was with a 4" lift and 35s.They will definitely rub when your wheeling with it.You could trim the fenders and they would fit though...
1969k10stepside is offline   Reply With Quote
Old 05-17-2007, 12:46 AM   #3
1tonswb
1tonswb's Avatar
Re: tires/lift
On my 74 I ran the 36 inch bias ply iroks. They are a tall tire (as in actual height and not advertised) and I had to run 8 inch springs to clear them without rubbing. You can prob get away with a 6 inch and some trimming. As far as the tire, there ok. Ive ran better. They wear quick though.
1tonswb is offline   Reply With Quote
