Old 05-16-2007, 09:06 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
'69 C30 motorhome question
Picked up my "new" motorhome the other day and after bringing it home realized the trans didn't go into park. It is a turbo 350. I also saw it has no "P" indicator on the trans position indicator on the column. Is this normal? Hard to believe the parking brake is meant to hold this heavy thing, cause it doesn't! Had a very hard time loading it on my trailer, which is angled since the brake can't hold it.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 05-16-2007, 09:21 PM   #2
uncle
Re: '69 C30 motorhome question
That's correct. I just bought a 70 and it's the same way. I was told it's internal,but have not talked to anyone about a fix yet.
uncle is offline   Reply With Quote
Old 05-16-2007, 09:22 PM   #3
Bob B.
That should be a Turbo 400, and yes, C-30's with Turbo 400's didn't have a park position back then. I think Gm was worried the internal park lock in the transmission wasn't strong enough for thje GVW of those trucks.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 05-16-2007, 09:23 PM   #4
kwmech
The motorhomes have a turbo 400. My 69 ex-motorhome GMC had the same thing----no park--same as you, not in the column or the trans. I swapped out the column for a tilt and rebuilt a different trans and swapped it in a couple of hours. I think GM did this to MAKE the owner of the vehicle set the parking brake.
Old 05-16-2007, 09:25 PM   #5
kwmech
The parts can be swapped in if you have a donor trans. I had a core already with the deep pan so I just rebuilt that and swapped out the whole unit
Old 05-16-2007, 09:34 PM   #6
msgross
msgross's Avatar
pics
msgross is offline   Reply With Quote
Old 05-16-2007, 09:34 PM   #7
uncle
Can it be fixed without pulling the trans?
Old 05-16-2007, 09:43 PM   #8
bad_turbo
turbo enthusiast
bad_turbo's Avatar
no computer to post pics. I'm using the library computer , but thanks guys for all the help. I will double check on the trans i.d.
Old 05-17-2007, 02:24 PM   #9
kwmech
I think so--the hardest part will be getting the pivot or pawl installed in the back/rear of the case, and either finding a little plug to put back in the hole or threading it and putting in a small pipe plug
Old 05-17-2007, 06:34 PM   #10
bad_turbo
turbo enthusiast
bad_turbo's Avatar
it is the turbo 400 trans. Hey Mike, you want to post some pics for me? I can email them to you.
Old 05-17-2007, 09:12 PM   #11
msgross
msgross's Avatar
sure.. msgross@hotmail.com anytime..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
Old 05-18-2007, 09:05 PM   #12
msgross
msgross's Avatar
pics added....
The Garage:
Old 05-19-2007, 06:21 PM   #13
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Wink Re: '69 C30 motorhome question
Thanks again Mike!! How do you like those mirrors on the burb?
Old 05-19-2007, 08:52 PM   #14
msgross
msgross's Avatar
I just nocticed them after I posted... did they work ok? Wasn't that the 67 burb with a 69 nosejob? Now for some clerance lights and a lift kit and you are set.
How's the wife like the motorhome? Still thinking about moving east again?
The Garage:
Old 05-19-2007, 10:16 PM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Nice RV
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is online now   Reply With Quote
Old 05-20-2007, 04:37 PM   #16
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Hey Mike Pm sent. Thanks Luv, there are several around here for sale right now if your looking.
