Old 05-17-2007, 12:19 AM   #1
jetfixr
Whats the deal with humps?
I have a 70 c10 that I converted from 4 on the floor to a 700r4, now I have a huge gaping hole in the floor where the stick used to go. I am not sure if it is considered a hi hump or a low hump. What I would like to do is get a hump out of an automatic truck and put it into mine, but all the automatics I look at the hump is not a bolt in peice like mine is, it seems the hump is an integral part of the cab. I did have a hump cut out of a truck that was headed to the crusher but I am really not sure how I would go about installing it. I am worried that a stock low hump carpet kit wont fit properly if I don't get the height just right.
jetfixr is offline   Reply With Quote
Old 05-17-2007, 12:26 AM   #2
powell72
powell72's Avatar
Re: Whats the deal with humps?
Stick trucks and BB trucks are high hump, only 2wd auto's are low. I would just make a filler for the shifter hole on your hump and order a high hump carpet kit.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 05-17-2007, 12:30 AM   #3
SacramentoJoe
Always Fixing Things
SacramentoJoe's Avatar
I have a 3 on the tree. It is a low hump.
Just an Average Joe
‘68 GMC 307 3spd – My dad's original truck
310,000 miles
SacramentoJoe is offline   Reply With Quote
Old 05-17-2007, 12:52 AM   #4
powell72
powell72's Avatar
Interesting.........how about 4-speed trucks and BB trucks have them......most of the time.
Chris
Old 05-17-2007, 01:05 AM   #5
cstm68
cstm68's Avatar
yeah before i converted mine to floor shift it was a 3 on the tre and is is a low hump
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 05-17-2007, 01:13 AM   #6
energiesource
mine was converted from 4spd to auto, but i dont know what it is, im guessing high hump
energiesource is offline   Reply With Quote
Old 05-17-2007, 05:07 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
big block/automatic trucks,
4X4,
4 speed
(gmc only) 305 V6 w/TH400 in a 1/2 ton
all these get high hump
Old 05-17-2007, 10:31 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's a past post of mine showing the differences of a low hump and a high hump.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-17-2007, 07:39 PM   #9
jorgensensc
jorgensensc's Avatar
HMMMM. I am 99.9% sure that I have a low hump that is boled into my truck, but the truck was originally a stick shift. The hole is more near the firewall on the curved part of the hump than the seat. I don't understand. I wanted to find a low hump bolt in that I could replace this one with. I'll take pics tomorrow.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-17-2007, 07:56 PM   #10
Rokcrln
Rokcrln's Avatar
For a low hump bolt in you will need to cut out the section from a low hump floor, drill the holes and bolt it in. All cabs started out as low humps and they cut out the hump for the above mentioned modles. All low humps are from the factory part of the cab floor not bolted in.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-17-2007, 08:36 PM   #11
sodak69c10
sodak69c10's Avatar
high hump is pretty easy to identify it is just that (high) from the floor pan height to the top on the hump it rises about 5 1/2"-6 " a low hump i belive is only around 3"-3 1/2"
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 05-17-2007, 08:47 PM   #12
PKelly
PKelly's Avatar
Here's a picture of a high hump in a '68 C20 w/ a 396/TH400.
PKelly is offline   Reply With Quote
