Old 05-17-2007, 01:44 PM   #1
ocbaud
Garage Queen Material
replacing oil pan gasket
will it be easier to replace the oil pan gasket if my front suspension is removed( to rebuild it with new bushings, etc)???
i figure it would be the best time to replace the gasket since its leaking, since i'll have so much extra room to move around under there.
also, i forgot but will i need to remove my timing chain cover to install a new gasket on the oil pan?
ocbaud is offline   Reply With Quote
Old 05-17-2007, 02:13 PM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow Re: replacing oil pan gasket
No nothing with the front sus. is really in the way of that job except maybe the front tires and even then there really not in the way but more for just getting more light in there to see.
And the timing cover can stay put it's the other way around your thinking of.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 05-17-2007, 02:21 PM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
Like Stepper said, nothing else needs to come off (except maybe the oil filter for pan bolt access) to replace the pan gasket. Put one of Felpro's one piece gaskets back in....those suckers are awesome.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 05-17-2007, 03:14 PM   #4
ocbaud
cool.
i figured i would do the gasket when i rebuild my front end since it seems like i would have more room to work.
Old 05-17-2007, 05:10 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I replaced my pan gasket with all of the suspension attached. No problem at all. There is a LOT of room for it.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
