Old 05-17-2007, 01:47 PM   #1
WORNBRAKES
Question What is this bracket for?
I have seen this on the 2 1970 4x4's that I have had. Nothing was attached to it so I am wondering what it is for. It is located on the passenger side just behind the tranny cross member. Thanks in advance for any and all help.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 05-17-2007, 02:07 PM   #2
Chris27
Blazerless
Chris27's Avatar
Re: What is this bracket for?
On my 72 K5 the transfer case (NP205) bolts to that braket.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
Old 05-17-2007, 02:26 PM   #3
kwmech
exactly--supposed to help keep the t-case from breaking the back of the transmision case when in low range---theoretically
Old 05-17-2007, 03:00 PM   #4
WORNBRAKES
Is it for a 205 only or will it fit the 203 and 208?
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 05-17-2007, 03:00 PM   #5
bowtier
Nobody rides free
bowtier's Avatar
Helluva spring pack on that thing!
'71 C10 LWB 400SB/350TH
'86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck
'06 HHR - wifes wheels
'01 Blazer - daily driver
"It's better to burn out than it is to rust."
-Neil Young
bowtier is offline   Reply With Quote
Old 05-17-2007, 04:52 PM   #6
1969k10stepside
I don't know about the 203s or 208s but the trucks that had Rockwell's have them too
1969k10stepside is offline   Reply With Quote
Old 05-17-2007, 05:09 PM   #7
Blazer1970
Blazer1970's Avatar
The 208 definitely did not use the frame bracket. Some 203s (early models) may have.
Blazer1970 is offline   Reply With Quote
Old 05-17-2007, 08:32 PM   #8
jamie72
jamie72's Avatar
touqe bracket, keeps from cracking the auto tranny case
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-17-2007, 09:58 PM   #9
WORNBRAKES
I was shocked to see it myself. It was fun to remove as well. I had to put my large jack stands on cynder blocks just to reach the frame.
Thanks for all the great info.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 05-18-2007, 12:06 AM   #10
Down south truckin
Down south truckin's Avatar
wanna sell it ? shipped to 30047 thanks Mike
Down south truckin is offline   Reply With Quote
Old 05-18-2007, 12:42 AM   #11
1969 GMC
1969 GMC's Avatar
The stickshift trucks had them too, at least mine did
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-18-2007, 09:25 AM   #12
1969k10stepside
So did my two 4wds that originally had 4spds
Old 05-18-2007, 11:35 AM   #13
1969k10stepside
I just peeked under my 79 K10 and it didnt have that bracket.It has a NP203
Old 05-18-2007, 11:43 AM   #14
babyJay
Arrived on a Pale Horse
babyJay's Avatar
my 79 K20 doesn't have it - 203 TC, neither does my 85 K10 - 208 TC
Are you sure that's a K5 frame?
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 05-18-2007, 07:53 PM   #15
RANDY COX
RANDY COX's Avatar
I was thinking all the 4x4's had them my burb has it.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-18-2007, 09:48 PM   #16
WORNBRAKES
The truck in the pic is a 70 K10 frame. It was a manual trany truck. No engine, tranny or t-case come with it.
Here is a pic of my K5 with a 203. Looks like it could mount right to the t-case.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 05-19-2007, 06:44 PM   #17
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
73 and up 4x4s with 203s and 208s didnt use that bracket but they did use a heavy rod that bolted to the same 2 holes in the transfer case and it ran up to the transmission to block bolt right above the starter. These were usually left off whenever a transmission or motor was swapped out, it was a real pain to get to that bolt with this brace in place. This bracket worked in conjunction with two more strut rods that went from under the motor mounts to the heavy cast transmission pan on automatic trucks.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 05-19-2007, 09:12 PM   #18
msgross
msgross's Avatar
my 68 K-10 manual with a rockwell T/C has that bracket. T/C bolted to one part and the other to the frame. I just bought new poly bushings for it...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-19-2007, 09:16 PM   #19
1969k10stepside
Yep,my 79 K10 has them rods.The tranny and t-case were removed and rebuilt before I owned it,I wonder how the previous owner liked dealing with them rods and bolting the t-case back to it.
Old 05-19-2007, 10:34 PM   #20
eedgell
It's the air up here
eedgell's Avatar
My 71 k10 4 speed 205 has this bracket, but my 79 k20 4 speed 205 does not. In fact the mounting surface on the 79 205 doesnt even have holes tapped in the case, just a smooth machined surface where the mounting holes would be.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-20-2007, 12:33 PM   #21
3/4tonterror
3/4tonterror's Avatar
i have that same bracket on my 70 with a rockwell t-case.
3/4tonterror is offline   Reply With Quote
