U joint
how do you know when they are bad, Have some vibration between 2500 and 3000 rpm, how can u tell if it is driveshaft, u joint, or what?
thanks paaw
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold ![]() |
Sierra Grande Club
Re: U joint
They will clunk when you shift into gear usually. You can also grab it with your hand and twist it and see/feel movement.
I think it sounds like it’s your tires. Have you balanced them lately? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Re: U joint
I've had them cause vibes before they got to the point of clunking or feeling loose, but the only way to tell if they aren't obviously busted is to take them apart and look.
#4 | |
Sierra Grande Club
Re: U joint
Was it only at a specific RPM range? Just wondering. s/t
Re: U joint
I don't hear any clunking, will take it to get tires checked
Re: U joint
not really just once i got over 60 it will start vibrating
Sierra Grande Club
Re: U joint
If they are the same size, you can have them rotated too.
s/t
Sierra Grande Club
Re: U joint
Does it seem to go away if you go faster than the speed that is starts to vibrate?
s/t
Zappaphile!
Re: U joint
any noise? sure it's not in your rear diff??
Mine has a hum that starts at about 45'ish and gets louder as speed increases.. new rear gears is on my list because of it..
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son Last edited by lbpd719; 05-17-2007 at 10:28 PM. Reason: forgot to mention.. |
Re: U joint
my truck vibrates over 60mph turns out i missing a tooth off the ring gear.
a kid in my class has a mustang that had about an 1/8"(no joke) of slop in the rear u-joint it vibrated
,Clint LOUD PIPES SAVE LIVES ![]() 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA |
Re: U joint
going to take it out on the interstate tomorrow and see if it stops after a certain speed and listen to see if it is whining(humming). did not vibrate, before changed trans, also had diffferent tires put on back. Don't think the guy balanced them. went from 235-70-15 to 275-60-15
#12 | |
Sierra Grande Club
Re: U joint
I still think its your tires - especially since you don’t think they balanced them. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 05-17-2007 at 10:46 PM. |
#13 |
Re: U joint
agree
#14 |
Re: U joint
#15 |
Re: U joint
it could be nothing, happened to me, i thought it was something with the drive shaft but the joints and the bearing are good so i balanced the tires, still there, the gears in the diff are fine and yet it still does it a bit, my brothers 05 f250 4x4 does it, my brother inlaws 95 nissan 4x4 does it, so it could just be something you didnt notice before and now for some reason you do, just like i did
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#16 |
Re: U joint
could be harmonics to if it does it at a specific speed not above or below it maybe everything is just right and magnifies a smaller vibrations?
beats me, well, time to go back to work now
