05-17-2007, 11:22 PM | #1 |
BlahBlahBlah
Drop question
If I drop my panel 6" in the rear am I going to have problems with the cross member or bearing with the two piece drive shaft? I am putting in one of those bolt in c notches, so I have that part covered. Hoping I dont need a drop cross member. Or maybe flipping it would help?
Mark Last edited by CG; 05-17-2007 at 11:23 PM. |
05-18-2007, 08:01 AM | #2 |
Re: Drop question
CG, I'm running bags, 2" blocks and a CPP bolt in C-notch on my Surburban and haven't had any drive shaft issues. You will need to run shock relocators, though.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-18-2007, 09:38 AM | #3 |
BlahBlahBlah
Re: Drop question
Thanks Rob, I have all the usual stuff I need...notches, shock relocaters, adjustable panhard bar etc etc...Just wanted to make sure there weren't going to be any problems I haven't foreseen as this thing is finally starting to go together.
Mark |
