Old 09-12-2002, 02:33 PM   #1
MITCH1914
MITCH1914's Avatar
Question tire performance ?
i am thinking about buying a pair of hoosier quick time pro's 295-50-15. has anyone had any experience with this dot drag tire?
the gut wants 200 dollars for the pair they only have 5 passes on them.
how do they bite?
do they ride ok on the street?
MITCH1914 is offline   Reply With Quote
Old 09-12-2002, 08:47 PM   #2
mooneyes
mooneyes's Avatar
i knew a guy that had them on a 69 roadrunner 440 with nos...they hooked pretty good ,...only bad thing is you have to run tubes....
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 09-12-2002, 09:18 PM   #3
67shortie
Green club
67shortie's Avatar
That is a great size for a dot tire, and as long as you run over 20lbs on the street you should be fine with drivablilty, less and you are looking for trouble on the street.
And that tire is a soft sidewall that recommends a tube, but most of the time is not reqired unless the tire leaks a bunch. You should be able to get them cheaper, like 150-175. Good traction tire, I would go for it.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 09-13-2002, 08:31 AM   #4
MITCH1914
MITCH1914's Avatar
Thumbs up
thanks for the feedback
