Old 05-18-2007, 05:59 PM   #1
dmsteele92831
Transmission Shot???
It's a th400. Ok so last night my tranny feels like it is slipping, I drive it back home and park it. My tranny fluid was a little high and I went to empty some today, but I started the truck first and it wouldn't go into reverse or even neutral. It just stayed in drive. The pointer would be on park and neutral but when gas was applied it would go forward. I flushed about 7 quarts of fluid through while pumping the old fluid out (it was reddish-black). After that I'm still having the same problem, I'm guessing it's time to go shopping for a new tranny? Also should I stick with the Turbo 400? I have 3.07 gears.
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
dmsteele92831 is offline   Reply With Quote
Old 05-18-2007, 06:14 PM   #2
dmsteele92831
Re: Transmission Shot???
After searching some more, it looks like it may be my shift linkage? Anyone have pics of the shifty linkage in park?
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
Old 05-20-2007, 12:05 PM   #3
Aarons72s
Here is a bump for you.
Aarons72s is offline   Reply With Quote
Old 05-20-2007, 02:45 PM   #4
shortbed70
shortbed70's Avatar
check your set screw on the shaft comming down from the firewall. It could be slipping when you try to change gears.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-20-2007, 06:09 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You don't really need to know where it needs to be... Have an assistand who is strong enough to hold the brake pedal, get in while you are under the truck, have them (with the engine off) slowly go through the gears, while you are looking at the linkage on the side of the tranny. Not only should you be able to see the linkage move, but you should hear a definate clink through each selection.
You may still have tranny issues, but making shure the linkage is working is the first step.
Did you chainge the filter on your tranny fluid flush? If not, you may well have just wasted your time and money... the filter may well be clogged.
The fluid being overfilled is a good sign of overheating...was it all foamy too?
Old 05-21-2007, 03:29 AM   #6
dmsteele92831
Where's the filter on it? But no it wasn't foamy
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
Old 05-21-2007, 03:57 AM   #7
68K20 x Drill
The filter is inside the pan, along with a vital part of the shift mechanism
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 05-21-2007, 02:06 PM   #8
dmsteele92831
Guess I'm droppin the pan!
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
