transmission crossmember
i need to know if all the auto trans crossmembers are the same?? i need one for my turbo 350 and i can get one off of a turbo 400. both are 72 c-10. thanks
The Older Generation
Re: transmission crossmember
I think there is a difference in them. I have one of each out and I will take a picture of them in the morning... LockDoc
thank ya there lockdoc it sure would help me out
The cross members are the same except the TH 400 cross member has a bracket attached to it to support the e-brake cable. Attached is a pic of the TH 400 cross member with a cable mocked up on it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Here's a comparison between a 350 & 400 cross member. As you can see from the pics there are some differences in the way they are made but the overall dimensions appear to be the same. The bottom part is different where it bolts to the frame and the angled support that goes to the top of the frame is different also. Second picture, the TH400 is on the bottom. It has the emergency brake cable loop on it, the TH350 doesn't. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-06-2020 at 11:29 AM. |
