#1 | |
BBC oil pressure?
Workin on a 97 1/2T, its got a transplanted mid '70s 454 in it.
When you first start it, oil pressure is good.....3/4 of the guage and damn near maxed with highway RPMs. But after about 15 mins or however long it takes to warm up, the oil pressure dramitically drops. wont even register at idle, barely moves/flickers at RPM. Any idea what would cause this. I thinks its got 10-30 Mobil 1 in it, other than that I have no idea. Thanks, Mitch-
Re: BBC oil pressure?
The senders on the 88 & up trucks cause a lot of trouble. Does it have a mechanical gage or the factory electric?
#3 | |
Its got a set of them Equiss mechanical guages....or how ever they're spelled.
No idea then. I have Equus gages in my 89 & they work great. try the 88-98 board maybe...
http://67-72chevytrucks.com/vboard/f...splay.php?f=12 |
#5 | ||
Thanks for the link, sadly it doesnt help though. Where as its not using the computer...or any of its guages. Lol, I think I forgot to mention that it was carbureted...I appologize for the lack of info there.
Active Member
I would go buy another gague- prefer mechanical and plumb it in as my 1st double check.
Actually - change you oil filter 1st - put on a napa gold or a wix filter - the bypass valve in the filter might be an issue.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
![]() Join Date: Aug 2004
Try another gauge and then I'd also change oil to 15-40 and see what that does. If it's still that low when it's warmed up your bearings are probably toast.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#8 | |
Cam bearing?
Active Member
Just for informations sake what should the oil pressre be at numericaly that is?
"The Great State of Florida" |
#10 | ||
Not to sure about BBCs though, Ive only only had one...the one in my truck. It runs about 15 at idle, and 30-35 at RPM. Im probably wrong though.....thats just what I have noticed through out my years.
I was experiencing a similar problem with a 396. At 1st I thought it was the gauge, but it turned out to be bad/worn out main bearings.
Sorry to be the bearer of bad news.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
#12 | |
Meh...its not mine, that just means more money for me. But more work at the same time.
#13 |
Active Member
I had the same problem with my '96 Impala SS with an autometer gauge, as corn stated it's most likely a sender issue. If it is an aftermarket gauge you can check the wire from the gauge to the sender and check that the sender is tight and that the wire/ connection is not burnt or frayed or partially disconected. Being a '97 assuming that it's a factory gauge I would check the 4 harnesses that connect to th PCM make sure they are tight and seated. Again check the sender and the harness wire if you can.
#14 |
I have a buddy with a factory BB 67 Vette 427/400hp. motor with only 40,000 miles. His readings are as follows ....
* Idle cold - 40 to 60 lbs pressure * Idle warm - 40 lbs. * Running @ RPM. - 60 lbs, esll. ![]() Oil gauge mech. ........................... I also run a mech. gauge on my 70'LWB.
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 05-22-2007 at 09:10 AM. |
#15 |
It's the air up here
Oil pressure will vary depending on the type of oil and oil pump. If not the gauge then most likely bearings. Pressure starts to build in the cam bearings first then to the crank assembly. Dont sound good.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
#16 |
![]() Join Date: Apr 2006
my 396 runs 35-40 at warm idle and 55-60 at highway. My 455 did the same thing, it was mains, in a motorhome..... can you say expensive!!!!!!
'69 Chevy CST#'s 396/TH400, A/C |
#17 | |
Main bearing look heavily worn (coppers showing), gonna pull the cam later and get a look at them bearings.
The front main bearing....it more worn than the others too. Almost like the belts were so tight that it lifted the crank up into the bearings.
