72 Cheyenne
Strange noise coming from driver side muffler
Only the driver side, it sounds like it has a frog in it's neck and it makes a small chirp noise, kind of a blurp blurp. My Mechanic friend says it's the Muffler and the Muffler shop says it's a miss in the Engine making it sound that way. What do you guys think?
I hope I understand your problem the right way...
I sounds just like the problem I had two weeks ago. When I was driving slowly it was hardly noticable, but putting the pedal down, it misfired like crazy. I waited until it was dark, started the engine and opened the hood... It was like lightning between two or three wires ![]() So I changed the wires and that solved my problem. ![]() Hope this helps.... Cya, Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb 1974 Chevy Camaro Z28 (Original) ------------------------- Capelle a/d IJssel, The Netherlands |
Weapons Of Construction
Wait till it's cool and feel around on the top and look at the bottom for any cracks. Mine sounded really wierd for a while. It had a crack which created a flap that buzzed at certain times. Finally the metal fatigued and fell off. No more buzzing noise, but it is a little louder now, with a 3" hole in the bottom of the muffler...
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
72 Cheyenne
Edmond,
What kind of sound was it making? Mine makes the chirp sound here and there but muffled blup blup sound is all the time. Thanks. |
SLICER AND DICIER
That's just FLOWMASTER'S FOR YA!! Sorry JMO, I had them and was so unhappy, cut them off and threw them in the trash. They were only on like a month or so. I bought MAGNAFLOWS.
01 Tahoe 22's 2/4 drop and tv's ![]() 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
72 Cheyenne
Yeah, I'm about ready to toss these things.
Dion, the sound is for me hard to explain in english, but it was a bit like 'blup blup' also.
But when I accelerated faster it sometimes fired in the exhaust... making a very loud 'bang' ![]() I noticed also loss of power on the highway... I had new exhaust and it sounded even harder, but that's normal, the old exhaust had more hole's in it than a Swiss cheese. ![]() I hope this helps... Sorry in advance if my explanation isn't really clear. Cya, Edmond
![]() Join Date: Apr 2000
I had the same broblem and it turned out to be the baffel in the muffler was comming loose. You could try banging on the muffler but it might not rattle. After I took it off you could shake it and here it rattle.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
NSane68!!! where did your get your Magnaflows?Thanks.
SLICER AND DICIER
I got them at my local muffler shop. But I've seen them in summit, jegs, ect.
