05-19-2007, 09:06 AM | #1 |
F.A.S.T. president
who sells -7" rear springs
I have read mention of 7" drop coil springs for the rear but I can find which vender has them. Can anyone point me in the right direction?
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
05-19-2007, 11:20 AM | #2 |
Re: who sells -7" rear springs
Thats a little extreme IMO. Can you get most of the drop with springs and the get some more with blocks?
05-19-2007, 12:12 PM | #3 |
F.A.S.T. president
It is, but I have a c-notch and already have -5" springs and 2 inch blocks. At seven inches I sill have too much rake with the tall MT tires I want to run. I don’t want to run bags because of the additional compressor and other accessories I would have to add.
05-19-2007, 12:19 PM | #4 | |
How tall is the MT? How low are you in the front? What year is the truck? You could run bags with out all the accessories. Keep a portable air tank close by at all times though. Are you running the truck on the drag strip? Last edited by BigTruckDriver; 05-19-2007 at 12:33 PM. |
05-19-2007, 12:38 PM | #5 |
F.A.S.T. president
Truck is a 71 . I dont want to go 3 inches on the block, the u-bolt nuts are already below the 15" rim. The tires are 30" tall from what I can remember.
I can’t remember how low I'm in front but I don’t think I can run a taller tire to level it out some. The rear tires I tried are not mine so I can always purchase a shorter tire for the rear. I just thought I read somewhere they make a 7" spring. The truck will never haul anything and it will unlikely see weekly use. I wonder if I can run bags without the unboard compressor since I wont have a neeed to lower and raise it on the fly.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 05-19-2007 at 12:40 PM. |
05-19-2007, 12:43 PM | #6 | |
05-19-2007, 01:25 PM | #7 |
all i could find was 6 in spring an 1.5 block or 2 in bl ece or gmc pauls
nickle and dime |
05-19-2007, 02:03 PM | #8 |
F.A.S.T. president
I Think the fronts are 28 high, 3 inch springs and 2.5 spindles.
Why would a 7" spring ride any different from a 5" spring as long as it didn’t hit the bump stop or coil bind like from the guys that heat and collapse the springs? I think the springs are just made shorter not weaker. I'm no suspension expert....any input is appreciated I dont have a need to run that tall of a tire, I just like the way the big tire fills up the wheel well, kinda like Rosie O in spandex If I could I would even go up to a 32" tall a tire thanks for looking, that’s all could find as well
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 05-19-2007 at 02:04 PM. |
05-19-2007, 06:25 PM | #9 |
Run the bags.
Two Firestone 2500# dbl. convoluted bags w/about 10ft total of DOT 1/4" airline & 2x schrader fittings would be around $200 depending on the source. Air them up to the ride height you want & enjoy the ride. Occasionally you'll have to put some air in (just like a tire occasionally requires air), but for the most part.... it's set 'em & forget 'em. Like BTD suggested, it's always wise to keep an emegency air source if possible.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-19-2007 at 06:27 PM. |
05-19-2007, 10:56 PM | #10 | |
