Old 05-19-2007, 05:56 PM   #1
CG
BlahBlahBlah
Car 4-speeds
If I wanted to switch from a truck 3-speed to a car 4-speed is there anything special I need to do or look out for?
Old 05-19-2007, 08:40 PM   #2
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
Re: Car 4-speeds
input and /or output splines may be different
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 05-19-2007, 10:20 PM   #3
Jim_PA
Re: Car 4-speeds
Yes, you need to flat shift it, and watch out for the tire smoke.
On a serious note though, if the 3-speeds are anything like th350's, you won't have any length problems. Most likely you'll need a th400 style slip yoke. I don't know enough about factory 3 speeds.
Hurst makes a shifter just for swapping car 4-speeds into trucks, might want to check that out.
Jim_PA is offline   Reply With Quote
Old 05-19-2007, 10:49 PM   #4
crazy longhorn
Fabricate till you "puke"
Re: Car 4-speeds
Aw crap.....here goes from the bests of me old memory If you are running a saginaw trans(7 bolt side cover), you can replace that with a saginaw 4 spd, or M 20/21 muncie......same lenght , same spline. Be aware that the 68 up truck bells had a larger pilot hole than the cars did . 67 or older on the truck bell was 4 11/16 on the center hole, same as car, wheras 68 on was 5 1/8 ". If you run the saginaw trans, you can use the front bearing retainer from the 3 spd on the 4 spd trans......for the muncie swap, have a machinist cut you a ring, or opt for a 67 or older bell. the truck bell will require a nut & bolt on the bottom 2 bolts, as the car trans is not threaded in the lower ears like the truck(not a problem, my richmond 6 spd is running on a stock 66 bell). Im damn sure there are a few details left out (forgotten over the yrs).... just ask if you need more info..... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-19-2007, 11:00 PM   #5
sodak69c10
sodak69c10's Avatar
Re: Car 4-speeds
muncie's take the same input shaft as a th350 i run a muncie so if you need any pics i can take some shots of it
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 05-19-2007, 11:11 PM   #6
Jim_PA
Re: Car 4-speeds
Some also used the 10 spline input shaft, just something to be aware of.
Old 05-20-2007, 12:19 AM   #7
sodak69c10
sodak69c10's Avatar
Re: Car 4-speeds
my mistake i just read what i typed i meant output shafts not input
th350s torque converts. duuhhhh...:nut: but anyways
,Clint
Old 05-20-2007, 08:21 AM   #8
Jim_PA
Re: Car 4-speeds
They use different output shafts too. Most use TH400 style
Old 05-20-2007, 08:45 AM   #9
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: Car 4-speeds
the biggest thing to look out for on car 4 speed's is FINDING ONE !
they are gone ! I used to keep them 3 or 4 at a time , $50 buck's was a good price for one , you can't find a smell of one now !!
I should have my rear end kicked for not keeping some of them , I had a T10 BW out of a wrecked when new 72 TA !! I love a 4spd they are really fun to drive ,,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 05-20-2007, 01:26 PM   #10
sodak69c10
sodak69c10's Avatar
Re: Car 4-speeds
no argue ment there
,Clint
Old 05-20-2007, 01:58 PM   #11
Jim_PA
Re: Car 4-speeds
Look for super t-10's early 70's all the way up to 82 in Camaros, Firebirds and maybe others?
They are basically an updated muncie, usually not as hammered as the muncies, and have a wider selection of gear ratios.
