It's the air up here
Anyone replace the A/C vent tubes behind the dash? You know, the slinkey pipe. It doent have to be the factory cloth wrapped stuff, but what have you guys used? And where did you get it?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
Re: A/C vent tubes.
I just did it, i used plastic repro from LMC, also used the center vent plug set kit, be patience when routing the new tubes.
I am a Referee of life.
Re: A/C vent tubes.
Any of the BB vendors will have replacements.Other than squirming under the dash the defrost ones were easy.I've never done the A/C ones.If you're replacing your dashpad or cluster then that is the time to do it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: A/C vent tubes.
What about the clips where the duct snaps to the ball housing? I noticed mine were broken slitely but it looked like a special end on the duct?! Do the kits come "as factory"?
Half a bubble off!
Re: A/C vent tubes.
It's been awhile since I replaced mine, about all I remember is there were cuss words involved. I will offer one helpful hint, if there is anything else you need to do under the dash (dash pad, stereo, ac/heater controls, wiring, new glovebox liner, etc.), plan ahead and get it all done while you have the dash torn apart. You'll be glad you did, I promise!
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
Re: A/C vent tubes.
And pull the seat & glove box unless your the size of a snake.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
New Member
![]() Join Date: May 2007
Re: A/C vent tubes.
Steve 67' C20 - Newest - My junkyard dog and work in progress |
Chief Honcho In Charge
Re: A/C vent tubes.
Warm the plastic tubes up with a hair dryer or the heat from your system...much easier.
I replaced all mine. Tim
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
