Old 05-19-2007, 07:44 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
how do i stop pinging?
i have noticed a high pitched clanking under my hood latley when i accelorate. i think it might be pinging. what does it sound like? i have about 9.0 compression and i use 87 octane. what are some things that might cause pinging? what are some steps to cure it?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 05-19-2007, 07:51 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: how do i stop pinging?
Sometimes it can be a timing issue, but can also be from low octane/bad gas. I have my timing dialed in, but if I run 87 my truck pings like crazy. It doesn't ping at all when I run 93. I'm sure there are other causes that I'm not aware of. Good luck getting the problem solved.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 05-19-2007, 09:36 PM   #3
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
I agree with Dave and this is where I would look first. Check the obvious before you dive in deeper.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 05-20-2007, 09:07 AM   #4
mnunn454
mnunn454's Avatar
If it goes away with better or higher octane gas then you have 2 options: Run the better gas, or retard the timing 2 degrees at a time until it goes away.
Before you go there though, make sure your vacuum advance is working properly. One of its main functions is to retard the timing during acceleration. It could be that your total and initial timing settings are fine and that it's just the vac advance that's not retarding like it should.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 05-20-2007, 10:06 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Check your mechanical advance too, especially if the engine is hard to crank when starting. When waiting for my engine to be rebuilt, the dizzy decided to get stuck on full advance...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-20-2007, 10:24 AM   #6
Boog
laying low
Boog's Avatar
Crm. 1972 cheyenne
chevrolet red and white
357ci, 9.0 comp, pro torker sr heads,
performer rpm q-jet, .454/.454 268H comp
Quadrajet carb, flowtech headers, 2.25 40 series
HEI, curve kit,TH 350, 3.07 gear
If this is the truck in question I see it has an HEI advance curve kit installed. I don't know how yours is set up but it may have too fast of an advance rate ( looser springs) for the compression and 87 octane gas. If using the lighter springs you can swap them for the next stiffer springs to delay the advance just a little bit. Or run higher octane gas or add a can of octane booster to each tank of gas.
Also what about coolant temps? If running a 195 stat back it down to 180 or so to also help the problem.
One other thing. An adjustable vacumn advance will help you to fine tune the curve too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-20-2007, 01:36 PM   #7
eedgell
It's the air up here
eedgell's Avatar
with Boog, with the mild cam set up you have you might be advancing too fast. 9:1 comp is not that high on compression. Check your timing curve, something closer to stock might work better in your case.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-20-2007, 02:12 PM   #8
WorkinLonghorn
WorkinLonghorn's Avatar
Did this noise just start without any changes made by you?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-20-2007, 02:51 PM   #9
shortbed70
shortbed70's Avatar
Carbon build up can also cause this due to carbon holding the heat and acting like a glow plug.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-20-2007, 06:08 PM   #10
crm318
crm318's Avatar
yes, the noise started with out me touching anything. i have a 180 thermostat.
1972 Cheyenne
