Old 05-20-2007, 12:45 AM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Front Cups
I got front cups from Suicide Doors and they dont seem to sit all the way down in the spring pockets on my 72. Has anybody else had this problem. It looks like i need to grind a taper on the bottom to fit down flat since the spring pocket is tapered. Also am I supposed to bolt the lower conrtol arm to the bottom of the bag through the cup or bolt the cup to the bag and allow the trucks weight to keep the cup in the spring pocket.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 05-20-2007, 02:13 AM   #2
SCOTI
SCOTI's Avatar
Re: Front Cups
Grind the cups so they fit your control arm. Some guys take more off as they're trimming them to fit in an effort to gain more drop.
Bolt the cups to the bags & allow the trucks weight to keep them in position.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-20-2007, 12:05 PM   #3
bedsled71
bedsled71's Avatar
Re: Front Cups
i have those and i cut them down to about an inch. they are made to be free floating and they wont come out from the weight and the air pressure pushing them to the control arm
bedsled71 is offline   Reply With Quote
Old 05-20-2007, 06:40 PM   #4
edflores
Re: Front Cups
blah. use flat plates on the bottom and cut out your lower arm. thats how mine was done.
edflores is offline   Reply With Quote
Old 05-21-2007, 09:30 AM   #5
jlaird
jlaird's Avatar
Re: Front Cups
This is a coming issue that has been talked about here many times before. The consensus is to buy the cups from Air Ride because they are slightly smaller in diameter and will fit better than the SD cups.
jlaird is offline   Reply With Quote
