![]() Join Date: Sep 2006
Have doughts about your Temp gauge.
These might be an easy way to see if it is working properly. I say not to much money to save a head gasket replacement, or even a warped head replacement, or worse.. They are a 16 PSI cap so make sure you can use it before buying it.. http://store.summitracing.com/partde...5&autoview=sku
Re: Have doughts about your Temp gauge.
Thats a lot quicker to install than the thermostat housing with the temp gauge on it.
I noticed they had some that were 13 PSI also.. So they may even have some with less if you call and ask..
