Old 05-20-2007, 01:52 PM   #1
1969k10stepside
Bolting 205 adapter plate to crossmember--what size bolts to use?
Ok,so I'm getting close (as in between now and next week) to bolting the motor,tranny,and t-case in the 71 shortbed.Now,the truck didn't have the drivetrain,or the bolts so I have no clue what size of bolts to use.
So...I think the bolts that go in the side of the 205 for the "torque bracket" are 5/8'' coarse thread, about 1 1/4'' long...correct?
What size bolts do I use that go in the bottom that connect the crossmember to the t-case?
Thanks,
Dustin
1969k10stepside is offline   Reply With Quote
Old 05-20-2007, 06:39 PM   #2
JAKES 68GMC
Aluminum slot wheels rule...
Re: Bolting 205 to crossmember--what size bolts to use?
They are fairly long, like 3 1/2" thread maybe?, and they are 5/8" coarse thread. I could go pull one out and measure it for you, but I'm not that kind of guy.
JAKES 68GMC is offline   Reply With Quote
Old 05-22-2007, 05:59 PM   #3
eedgell
It's the air up here
eedgell's Avatar
All the 205's I have been around are: 1 inch long x 5/8 on the torque bracket, and 3 inch long x 1/2 on the main mounts. All course threads.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-23-2007, 07:07 PM   #4
1969k10stepside
Thanks guys.I just bought some bolts like mentioned above and they worked...Now I have a transfer case to bolt in friday...
Old 05-24-2007, 07:13 PM   #5
JAKES 68GMC
Wait, aren't the crossmember bolts 5/8" thread as well? or do they have a 5/8" bolt head? Can't remember, been too long.
Old 05-24-2007, 07:48 PM   #6
1969k10stepside
I bought the size eedgell posted and they seemed to work.
Old 05-25-2007, 12:18 AM   #7
eedgell
eedgell's Avatar
3/4 and 15/16 head size.
Eric
Old 05-25-2007, 08:14 AM   #8
msgross
msgross's Avatar
I don't think my T-case bolted to a crossmember, only torque arm. I know the transmission bolted to it's crossmember, My T-case crossmember has a skid plate rivetted to it. It's a 221 Rockwell though so it might be different.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-25-2007, 11:25 AM   #9
1969k10stepside
Mine don't either.....It bolts to the adapter plate which bolts to the crossmember.I'd have to look at my rockwell t case I have,I dont remember how it mounts.
Old 05-25-2007, 01:59 PM   #10
1969k10stepside
Well,I got the transfer case in....the bolts were the right kind but the ones that bolt in the adapter werent long enough.Luckily I found one to work for now but I'm going to have to get some longer bolts eventually
Old 05-25-2007, 09:24 PM   #11
1969k10stepside
Re: Bolting 205 adapter plate to crossmember--what size bolts to use?
Well...I managed to find some grade 8 bolts the right thread,and right size to use so now the transfer case is completely bolted down....next is the tranny and motor
Old 05-26-2007, 04:45 PM   #12
eedgell
eedgell's Avatar
3 inch long 1/2 bolts were not long enough? What did you have to use?
Eric
Old 05-26-2007, 07:21 PM   #13
1969k10stepside
I used ones close to 4" long.They stick out of the adapter,but they work.Should the t-case have room to move forward and back some while its bolted down,I think it should have some room to move,but how much?
Old 05-26-2007, 07:41 PM   #14
eedgell
eedgell's Avatar
Wow! you must have some thick mounts or something. The T-case sould be able to move for and aft but not much more than the cross member allows. The cross member should bolt to the adapter with little deflection.
Eric
Old 05-27-2007, 06:47 PM   #15
1969k10stepside
Yes,the mounts are thick,but the bolts do stick out of the adapter a lot.
I was out in the shop today while it rained and the transfer case all bolted down moves forward and back about 1/2-3/4"...to much?
Old 05-28-2007, 12:27 PM   #16
eedgell
eedgell's Avatar
Are you bolted to your torque bracket?
Eric
Old 05-28-2007, 02:42 PM   #17
1969k10stepside
Yep
Old 05-28-2007, 03:04 PM   #18
eedgell
eedgell's Avatar
You should be good. You need some give when you install the engine and "suck" everything up tight. 1/2 inch is the world sometimes!
Eric
