Old 05-20-2007, 06:46 PM   #1
Luvlegs
Luvlegs's Avatar
HELP! Last minute Sunday night - TO Bearing problem
Hey all need some quick help,
All day work around the house - last few before dark, changed the throw out bearing - 72, 6 cylinder - I CAN NOT get the tranny back up to the bell housing - only 4 bolts - hangs up about 1 1/4" - I tried up, down, side to side, lower front, raise front, same on the other end - now have clutch pedal engaged (pedal depressed and held in with block) - even tried two bolts in bottom holes taking up any slack - didn't want to force so I stopped - Any help much appreciated (and the mosquito's are coming!!!!)
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 05-20-2007, 07:13 PM   #2
Luvlegs
Luvlegs's Avatar
Re: Last minute Sunday night - TO Bearing problem
ttt
1972 C10 L6 3OTT
Old 05-20-2007, 07:15 PM   #3
Evans
Evans's Avatar
Turn the tail shaft on the tranny , sounds like the splines aren't lined up between the tranny and clutch
Evans is offline   Reply With Quote
Old 05-20-2007, 07:19 PM   #4
Luvlegs
Luvlegs's Avatar
Been trying that also - it didn't seem to make any "clicking" noises like it was almost catching.... I'll do it some more - any more ideas? I found two posts where guys used long bolts and just kept going around tightening them.... I'm afraid that might break something.....
1972 C10 L6 3OTT
Old 05-20-2007, 09:03 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Sounds like you haven't got the input shaft aligned with the crankshaft.Did you use an alignment tool when you pulled the tranny?It keeps the clutch disc splined hole centered with the crank hole for the input shaft.
That's the first thing that came to my mind.I did my first many years ago and did not know to do this.I spent 2 days on a simple job.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-20-2007, 09:33 PM   #6
cmcolumbus
cmcolumbus's Avatar
Did you dry fit the bearing before instolling ?
cmcolumbus is offline   Reply With Quote
Old 05-20-2007, 09:42 PM   #7
Jim_PA
Use floor jacks if need be, and get the engine and trans as perfectly lined up as possible. If they don't go straight in, or with a slight twist, something is wrong. Get the trans out of the way, and look in to see if the clutch disk is somewhat centered with the pilot bearing.
Take your time getting it perfectly lined up. I've had them be a real PITA, and the next time, they fall together.
Jim_PA is offline   Reply With Quote
Old 05-20-2007, 09:42 PM   #8
truckdude239
truckdude239's Avatar
why is the pedel depressed? this will release the clucth disc causeing it no to line up
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-20-2007, 10:54 PM   #9
e rock
Yup. Pull them back apart a few inches, insert your clutch alignment tool, then release the clutch pedal and leave it that way. If you don't have your tranny's input shaft there to hold the disk in place and you release the pressure plate, the disk will fall down and you won't be able to put it back together.
If you don't have the long bolts to make 'rails', you can still insert the lower bolts to get an idea of your alignment and then just measure the distances all around to make sure you're going in straight.
e rock is offline   Reply With Quote
Old 05-21-2007, 12:09 AM   #10
Luvlegs
Luvlegs's Avatar
I called my dad - it's been 20 years since he's worked on one - I had to have it done before dark - he said "crank it over" and the try again... I hesitated, but said wth and did it - I got back underneath picked it up off the jack and it slid in.... done!
1972 C10 L6 3OTT
