Old 05-20-2007, 07:10 PM   #1
northerngmc
northerngmc's Avatar
Thickness of brake shoe material
How thick should the pad be on a brake shoe on a 69 GMC 1/2 ton?
I am pulling the drums for inspection. The brakes were working fine but I want to know that they are fine before I put it on the road.
How thick are new shoes and how thin should they go before replacing?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 05-20-2007, 07:23 PM   #2
Bob D
Rolled on Paint Club
Bob D's Avatar
Re: Thickness of brake shoe material
I dont know how thick they are, but here is a pic of one of mine after rebuilding:
Bob
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 05-20-2007, 07:25 PM   #3
longhorn70gmc
longhorn70gmc's Avatar
About how much are you guys paying for the pads? Mine are due! Thanks,
Respectfully
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 05-20-2007, 07:39 PM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
The minimum thickness is 1/32" above the rivets. Also any cracks,glaze or fluid contamination warrants replacement. Personally,I like a little more meat on the shoes and replace them sooner than these specs would dictate.- Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-20-2007, 07:43 PM   #5
centsless
sufficiently talented fool
centsless's Avatar
Minimum thickness requirements vary from state to state for inspection purposes. Here in MD, It is 2/32from the web on bonded shoes, and 2/32 above the rivets on riveted shoes. New shoe thickness on the trucks is somewhere around 6/32.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 05-20-2007, 08:47 PM   #6
WorkinLonghorn
I stand corrected. Info was from the infamous "Haynes" manual.
Old 05-20-2007, 10:56 PM   #7
northerngmc
Thanks everyone.
I justed measured and I have about 5/32 of brake lining so I think I will just repack the wheel bearing, new wheel seals, clean everything up and readjust.
Blaine
