Old 09-12-2002, 08:56 PM   #1
68_GMC_910
what would Neal do?
68_GMC_910's Avatar
how do you make a 406SBC?
dang... I feel like a dumbass asking this because I know that it's common knowledge...
but I'm guessing it's a 400 bored out... 0.30 over?
I wish I had some formulae to calculate this stuff...
1968 GMC 910 Long Step 250/3onTree
1969 Chevy C10 longfleet, 350/350
68_GMC_910 is offline   Reply With Quote
Old 09-12-2002, 09:08 PM   #2
Eddie H.
Eddie H.'s Avatar
You are correct, a 400 bored .030 yields a 406 .
I've got a 404 in mine. It's bored .020 over.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 09-12-2002, 10:13 PM   #3
tom hand
CCRider
tom hand's Avatar
Engine Cubic Inch Formula: BORE x BORE x STROKE x .7854 x NUMBER OF CYLINDERS
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 09-12-2002, 11:24 PM   #4
Johns70
Johns70's Avatar
ok but how do you get a 406 stroker?
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 09-13-2002, 12:48 AM   #5
68_GMC_910
what would Neal do?
68_GMC_910's Avatar
Thumbs up
Thanks, guys. That was exactly what I was wanting to hear!
Old 09-13-2002, 01:01 AM   #6
68_GMC_910
what would Neal do?
68_GMC_910's Avatar
oh, and what's the difference between the 400 and 350 blocks other than the bore diameter? I know water jackets and heads are a little different, but basically what I wanna know is can the 350 block, (with the help of the 400 crank) go as big as 406 or do i need a 400 block to go big-bore???
Old 09-13-2002, 03:54 AM   #7
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
you will need a 400 block to build a 406, all your doing to it is increasing the bore size to .030 over, but a 350 block with a 400 crank and a few other mods will make a 383 stroker.
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 09-13-2002, 09:59 AM   #8
bigjimzlll
bigjimzlll's Avatar
the biggest you can go on a 350 block(safely) is 388ci. which is .060 over and 3.75 crank..you can use a bigger stroke crank for more cubes.. but then it gets costly.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-13-2002, 10:26 PM   #9
Eddie H.
Eddie H.'s Avatar
If you're willing to spend the cubic dollars, I have seen small block 400's stroked to make a 427. PAW used to sell a stroker crank kit. For the same money , though, you could probable build a good Big Block, so why bother.
Old 09-14-2002, 12:20 AM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Chevy now offers a 383 crate engine that has a 4.00 bore but uses a special 3.80 crank.This gives a 383 without an overbore.That would make a 393 (I think).
So in conclusion lets say you can get cubic inches but they cost cubic $$$.
BTW one of the magazines did a 454 smallblock but I think they used a special aftermarket block and could have built a nice BB and most of the rest of the truck for what they spent.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
