05-21-2007, 01:02 AM | #1 |
Rear axle not centered in wheel well
I have a 71' Suburban with a 6" all spring lift that came on the truck. Is it normal that the rear tires are further forward in the wheel well? Is there any way to center them? Thanks.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
05-21-2007, 05:27 PM | #2 |
Re: Rear axle not centered in wheel well
Yeah, Off Road Design sells small blocks with offset to work with spring pack center bolt to move axle one way or the other. 4crawler also make them. Good luck.
05-21-2007, 05:57 PM | #3 |
my 68 is the same....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
05-21-2007, 07:01 PM | #4 |
Well, Whoop-dee-do!
You can drill a relocated hole in the axle's spring pad if not too far off. Do the same on the top plate that your u- bolts go over- so the u- bolts will be straight. I've done this many times.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
05-21-2007, 08:15 PM | #5 |
my top plate is cast... you're better to buy a new one that has three holes, one in center and two for movement fore and aft...
05-21-2007, 10:24 PM | #6 |
www.diy4x.com makes some really nice stuff. spring perches with mutliple holes, and plates with a slot down the middle. BEEFY stuff!
05-21-2007, 11:09 PM | #7 |
Thanks for the help guys! The stuff at diy4x looks nice. I'm about to put a
14 bolt in so the spring perches they have will be perfect.
05-22-2007, 06:48 AM | #8 |
First I'd check to make sure the P/O didn't reverse the leaf packs when they were installed.
Or depending on the amount it's going to take to center up in the wheel well, turn em around. The plates memtioned above from ORD are called 'zero rate' blocks in case you choose to order a set. I have a set on my 14FF to move the axle back 1.5"s and they work great. |
