Old 05-21-2007, 03:43 PM   #1
six4flat
six4flat's Avatar
shocks
i put some 3" drop coils in the front yesterday but now i need the right shocks. i still have the coil overs that were on but now theyre smashed all the way down and when i go over a speed bump or any bumo it just hits hard an solid. i tried the auto part stores and they couldnt help me. so i came to the experts here, can you guys help me?
six4flat is offline   Reply With Quote
Old 05-21-2007, 03:48 PM   #2
six4flat
six4flat's Avatar
pix
a before an after. tires used to be 235/75/15 now theyre 225/60/15
Old 05-21-2007, 04:34 PM   #3
slepysal
slepysal's Avatar
Re: shocks
Ted very nice !!!! I got the rear from THE TRUCK SHOP, I have some KYBs up front that worked out
slepysal is offline   Reply With Quote
Old 05-21-2007, 05:34 PM   #4
six4flat
six4flat's Avatar
Re: shocks
do i need to get a a special kind? or just stock ones? like do they have ones for lowered vehichles?
Old 05-21-2007, 05:47 PM   #5
slepysal
slepysal's Avatar
Re: shocks
Yes you need the ones for a lowered application. www.truckandcarshop.com
Old 05-21-2007, 05:54 PM   #6
six4flat
six4flat's Avatar
Re: shocks
alright thanks sal
Old 05-21-2007, 06:46 PM   #7
slepysal
slepysal's Avatar
Re: shocks
Six4flat Man your truck looks good !!! nice job I'm digging the white roof
Old 05-21-2007, 06:51 PM   #8
six4flat
six4flat's Avatar
Re: shocks
thanks sal....i just want your white walls to set it off. i been googling shocks all morning found some different ones an thinking i can get a part number for them an go to winchester auto an see if they can order them for me
Old 05-21-2007, 07:02 PM   #9
62ChevyStep
62ChevyStep's Avatar
Re: shocks
I went with Toxic Shocks I think they are made by Rancho, but are for lowered sport trucks.
http://www.streetbeatcustoms.com/toxicshocks.html
http://www.streetbeatcustoms.com/toxshocchevg.html
39.95 each, great ride, I have a 3.5/5 static drop
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 05-21-2007, 07:04 PM   #10
six4flat
six4flat's Avatar
Re: shocks
yea those are the ones i was thinking about ordering. i found them a little cheaper here http://www.stylinconcepts.com/parts..../categoryid/30
Old 05-21-2007, 08:59 PM   #11
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: shocks
I can get the part number for some stock shocks that you might be able to find at a parts store....
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 05-21-2007, 09:01 PM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: shocks
....well what I meant was a shorter, replacement stock shock
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-21-2007, 09:02 PM   #13
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: shocks
Nice black finish !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-21-2007, 09:22 PM   #14
six4flat
six4flat's Avatar
Re: shocks
that would be great john.....did you get my PM about the show this weekend?
Old 05-21-2007, 09:22 PM   #15
Daniel 61 Apache
Daniel 61 Apache's Avatar
Re: shocks
Did you go with the ones for a 1965 on your 1962?
Daniel 61 Apache is offline   Reply With Quote
Old 05-21-2007, 11:37 PM   #16
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: shocks
I did...how far is it anyway, from San Jose ??
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-21-2007, 11:47 PM   #17
19GMC63
19GMC63's Avatar
Re: shocks
wow, what a difference paint makes. Love that stance.
Nice truck.
19GMC63 is offline   Reply With Quote
Old 05-22-2007, 02:24 AM   #18
six4flat
six4flat's Avatar
Re: shocks
thanks guys. im getting rear springs from a jeep wrangler so that'll drop her 3" in the back. John its about 2.5 - 3 hours deppending how fast you drive
Old 05-22-2007, 01:22 PM   #19
62ChevyStep
Re: shocks
Since I have a 86' C10 front crossmember, w/2.5 drop spindles and 1 inch drop springs, we measured the full stroke then figured what was best. We also went with custom upper brackets (http://www.streetbeatcustoms.com/arta008f-sy.html) we cut the length and reinforced the frame with a plate. I can shoot some pics and post if you would like.
The rear we used the stock mounts and again just did the math with the stroke, allowing for appropriate compression and extension.
Old 05-22-2007, 08:20 PM   #20
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: shocks
I had my buddy Rich (speed merchant) do some research on the shocks. A stock shock will do 2" drop. He checked with KYB and BellTech. They supposibly dont make a lowered shock.
To get the best ride.....extending the upper shock mount would be the thing to do. Styling Concepts might have something different, though.
My truck shocks are all blown out know from being used as bumpstops...
Not sure on your front end, but what I did on my truck was cut out the bumpstop/steering stop mounts completely from the lower arm. This gives the truck like 2" more of travel...then use low pro bumpstop bolted to the lower a-arm. I have an xtra set you can have if you need them.
I was trying to find a smaller (shorter) shock from a different application that would work on your truck. (For example, back in the day I used to use Opel shocks on the front of slammed VW's)
If a stock stock will work for a 2" drop....then a "lowered" shock will be perfect for your truck. Although, extending the top mount will give you even better dampening !
Hope this helps....
John
Also..you and Sal want to get together and Q it up one of these days ??
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-23-2007, 12:22 AM   #21
six4flat
six4flat's Avatar
Re: shocks
thanks john that info helped alot. i think im going to order the toxic shocks from Styling Concepts 80 bux for both shipped. yea we should have a bbq. i wanna see the vdub you have, back in the day my pops used rebuild those motors all the time. maybe one day i can stop by your shop
Old 05-23-2007, 01:39 AM   #22
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: shocks
Right on...do me a favor, when those shocks come in...can you give me compressed and extended measurements ?? Measure from eye center to eye center. Might take two people though.
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
