Old 05-21-2007, 06:41 PM   #1
David Herrera
Chevy big block motor mount question
The Frame mounts have an oversized opening, I need to know if a grommet is needed to bolt up to the motor mounts? the 72 truck came with a small block but changing over to a big block.
David Herrera is offline   Reply With Quote
Old 05-21-2007, 07:22 PM   #2
john
member #16
john's Avatar
Re: Chevy big block motor mount question
Do you have the 68-72 big block eng mount brackets with the big hole? If so they use a different mounts with a rubber pad on both sides of the frame stand.
john is offline   Reply With Quote
Old 05-21-2007, 07:33 PM   #3
David Herrera
That's correct, the 72 big block frame mounts with the 1 1/4 inch opening. Where would I find those motor mounts?
Old 05-21-2007, 08:22 PM   #4
john
member #16
john's Avatar
meant to say 68-71. the 72 mounts are like the 73 and newer. I think some of the board vendors will have them, but prepare for sticker shock. There is a FAQ article on Using different big block mounts.
http://67-72chevytrucks.com/vboard/s...d.php?t=122645
http://67-72chevytrucks.com/vboard/s...d.php?t=128765
Old 05-21-2007, 09:38 PM   #5
David Herrera
Thanks John I found the right mounts at Truckandcarshop.com
Old 05-21-2007, 10:34 PM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
You can make 1/4" thick square washers and grade 8 bolts and it can work that way also.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-22-2007, 12:08 AM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
72 is unique to itself. Please for your sake talk to BIll at Vintage CHevy Trucks before you buy.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
