09-12-2002, 10:48 PM | #1 |
drag it like you stole it
seats
what are a good set of seats i should start looking for? i need them to be able to sit 3 people (two people and a car seat. family man. =) maybe the middle could fold down or somthing? any suggestions?
negative camber //LA\\ |
09-13-2002, 11:19 PM | #2 |
I've got a straight bench out of a '94 regular cab pickup for my '72 and it works great and looks straight and clean. Put in new should belts and center belt. HUGE difference. Also, the child carrier works well, mine had one in it for years.
Just put a set of 60/40 splits from a '93 suburban in my '72 suburban. Again, nice fit. However, I'd take a straight bench anyday, just for the clean look.
'72 GMC 1/2T 4x4 1500 Super Custom pickup (current) past rides were: '70 Chev 2wd farm truck '71 GMC 2wd 1/2T 402 nice! '72 Chev 2wd 1/2T 396 '72 GMC 3/4T 4x4 2500 Super Custom suburban. Bozeman, Montana |
09-14-2002, 11:35 PM | #3 |
how much room do you have behind that seat in the truck? and plenty of leg room?
09-14-2002, 11:45 PM | #4 | |
Seņor Member
Re: seats
Kenneth
09-15-2002, 02:28 AM | #5 |
Not much room behind the seat when its all the way back on the rails. However, the back is thinner than a stock seat, so there must be a little room back there. When my wife drives it and moves the seat forward, there's got to be 3" back there.
About the same amount of room under the seat for odd crud. Plenty of leg room, definitely no problem there. If I had a brain, I'd have a digital camera by now and would post pictures. One of these days...
09-15-2002, 09:42 PM | #6 |
XXL
i have pics on my camera but when i hook the camera striaght up to the computer it doesn't boot up for some reason. i gotta get one of those little USB memory stick readers. but i'm going to try and do something quick because i knew as soon as i changed my signature people were going to ask. i should have better prepared. hehe. its a stock floor body drop. frame below the cab is cut down 3". bed floor is raised 3". core support mounts are lowered 3". big notch out back. waiting on my welder to finsh things up.
09-15-2002, 09:56 PM | #7 |
I put a 90 model 1500 in my 70. Like they said about same room as stock bench...just way more comfortable..
Now I forget who wanted a picture...but if you want to see...you can see my web page and it shows the fairly simple changeover.. Pleae forgive the ugly color combo of the seat to my truck.
09-15-2002, 10:09 PM | #8 | |
Seņor Member
Re: XXL
What are you doing to address the front fender clearance problem (see pic below)?? Kenneth
09-15-2002, 10:50 PM | #9 |
why not just cut all that out? run a little reinforcement, if needed.
09-15-2002, 10:55 PM | #10 | |
Seņor Member
That pic is of the stock fender, and you can't cut anything out to give more clearance unless you do something about the hood hinge that bolts in those holes. What did you do to get such a big drop and still have fender clearance and still bolt up the hood? Kenneth
09-15-2002, 11:06 PM | #11 |
actually, two new front fenders, cowl hood, outer grille, and front rollpan should all be here tomorrow or the next day. so i havent gotten to that yet. the fram is still at the welding shop. i know it can be done. IF customs has done a 72' layin door. rockers are cut off. if they can do a 6"+ body drop. i shouldn't have to much of a problem doing a 3"
09-15-2002, 11:09 PM | #12 |
09-15-2002, 11:32 PM | #13 |
You need a set of factory 67/68 buckets with the centre jump seat/fold down console. I use it to put my daughters car seat on when I take the truck to shows.
I just had mine reupholstered"
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
