Old 05-21-2007, 08:24 PM   #1
RedZ71
Junior Member
RedZ71's Avatar
so dont laught at me for a dumb question... :)
what all is involved with changing the rear end from opendiff to posi?
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 05-21-2007, 08:25 PM   #2
Rokcrln
Rokcrln's Avatar
Re: so dont laught at me for a dumb question... :)
Rokcrln is offline   Reply With Quote
Old 05-21-2007, 08:28 PM   #3
Rokcrln
Rokcrln's Avatar
More or less a full rear end re build. The carrier needs to be replaced with a posi unit and if you are doing that you will want to change the bearings and seals. Do you have the right ring and pinion that you want ? If not do that at the same time. Or just find a used rear end that has a good posi. Personaly I would have a shop set it all up for you because the labor is cheap compaired to the parts. So if you do it wrong it will get very $$$
Kevin
LFD Inc.
Old 05-21-2007, 08:49 PM   #4
RedZ71
Junior Member
RedZ71's Avatar
well based on your threads, if *you* say axel swap, ill take your word for it.
Jonathan
1971 LB C10 Custom
