05-21-2007, 08:30 PM | #1 |
Cultural Infidel
DIY Bedliner, any pics?
I'm going to do the DIY bedliner. Could those that have done this post pics and state what product they used, with pros and cons? Thanks in advance.
-Mark
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold! It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
05-21-2007, 10:19 PM | #2 |
Re: DIY Bedliner, any pics?
haven't done this before but talked with a friend that has, and he said he uses herculiner..he also sprayed it in using a siphon sandblaster gun that he got at the parts store he said it was like $9.00 and when your done just throw it away.
hes going to be doing it again on a s-10 shortly . i'll try to get some pics |
05-21-2007, 10:31 PM | #3 |
hey sir0066 i would like to see these pics it is an intriguing idea
11 Surbaban 70 C 10 still in progress |
05-21-2007, 10:43 PM | #4 |
67-72 Addict!
Board member CENTSLESS did a great job spraying his bed liner! . I've used the roll on Bondo brand Truck Gaurd and liked it. I recently had my ZR2 sprayed at a shop and love it!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-21-2007, 11:17 PM | #5 |
I run a spray-in shop. You cannot get the same results from a 100 dollar kit that is comparable to what my 15,000 dollar Graco machine lays down. This is an area where you get what you pay for, IMHO.
Alex 1971 Lil' Red 350 SBC 700R4 |
05-22-2007, 01:03 AM | #6 | |
I did the whole interior of my Land Cruiser in the cheapest stuff I could find - Duplicolor. It was like $40 for a gallon of liner and a loop-knap roller to lay it down with some texture. The best part of this stuff is that they also sell it in rattle cans for $7. The rattle cans are great for touch-ups and for getting a little extra in places that the roller can't get to. I would not use it to do the bed of a truck that gets used. It's fairly thin (something I wanted for fitment since it's the interior), so it's relatively brittle and will chip off if I drop something sharp onto it. It stands up really well to wear, except right below my right heel, but that only wore when my brake master puked and softened the liner. From what I've seen, it's similar to herculiner but cheaper. Just for clarity - I would not use one of these kits in my truck bed since it actually has to haul stuff. |
05-22-2007, 01:18 AM | #7 |
Sinister Exaggerator
yah, if you actually going to use the bed of the pickup for "work" you probably should pony up the dough for the real thing. but if your just want the "look" (like i do) then the whole idea of using a grav feed sand blaster setup sounds pretty cool. plus you can say you did it yourself.
we need some pictures though!!
69 c10 Chevy Long Fleet 350/350 *under construction* Poor man's disc brake upgrade with HydroBoost from '82 diesel Blazer tank with "John Fabris" stake pocket filler (Genius!) |
05-22-2007, 07:32 PM | #8 | |
Cultural Infidel
Still looking for pics of any DIY liner applications. -Mark
05-22-2007, 08:48 PM | #9 |
no pics, but you can get a liner gun at most paint supply places for $30. They lay it on a LOT better than peablaster gun..... been there done that.
'69 Chevy CST#'s 396/TH400, A/C |
05-23-2007, 06:04 PM | #10 |
I used a product called hippo liner and got the paint to mix in with it so it matched my truck. Cost around $140 if I remember correctly for everything I needed and I sprayed it in. Still have the gun. This is what it looked like
Pros- Cheap and easy to do, and looked good Cons- Scratched easy and when scractched it was a lighter blue. Showed dirt easy and was hard to keep clean, I did have a bed cover and a hole in the bed after I bagged it.
70' C-10 SWB 71' C-10 SWB 2001 Audi S4 1994 Ford F-150 1974 Gremlin 1959 Apache (Will be For Sale soon) 1972 Chevelle (Will also be For Sale soon) |
05-23-2007, 06:05 PM | #11 |
Oh, I got all this from Car Color and they rent out the gun or you can just keep it like I did.
05-23-2007, 06:51 PM | #12 |
I just did mine with the Raptor kit (flea bay). I have pics, but their too dark so it won't do any good to post them. It needs another coat for thickness. But the texture and durability seems to be good so far. It comes with a gun in the kit, and is a two part kit. Fill, shake, and shoot. Do a lot of taping first as that stuff will stick to anything it touches.
My boss put some of the duplicolor stuff in his bed (1 part kit), and it is peeling off big-time. May be a lack of prep work, I dunno. He says he did everything like he was supposed to. But he is known to get in a hurry sometimes. I agree that the result would be a lot better had I taken it to a shop. But mine will work for me, especially after I get the second coat sprayed in. And I've only spent $100 so far. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! Last edited by Psycho71; 05-23-2007 at 06:52 PM. |
