Active Member
SBC AL Intake Sweet
I have a very nice Weiand manifold that fits a small block chevy pre 87 heads with out modification.
87-92 heads can fit with modification to the center 4 mounting bolts. This manifold looks to be new. It has been mounted on an engine - hence it still has the gaskets attached to the bottom. However the bottom and inside are clean enough to eat off of! This is a cool manifold - the center plenum divider can be used, removed or modified to make a drop split plenum. The intake is painted chevy orange with some peeling in a few spots. Up to 19 more dyno-tested horsepower. These 360 degree Weiand X-CELerator single plane manifolds make their power in the 1,500 to 6,800 rpm range, which makes them the ultimate manifolds for high-performance street, drag, marine, and Oval Track engines. The carburetor mounting pad is designed to accept all current aftermarket performance carburetors, and includes an open-style plenum for increased flow. Best suited to engines equipped with aggressive camshafts, headers, and high-output ignitions, these intakes are sure to put a smile on your face. These sell $129.95 + 10.95 handling from Summit. I would like $50.00 plus the ride. Paypal (no credit cards please), money order would work as well. Please respond within the ad so we know who is in line.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() Last edited by 1968SWBBigBlock; 05-21-2007 at 10:07 PM. |
Re: SBC AL Intake Sweet
sold pm me your info and thanks Mike
hav'n fun be'n me ![]() |
