Old 05-22-2007, 10:27 AM   #1
blazer2007
is blazer much heavier than p.u. ?
I was wondering if 78 2 wheel dr. blazer is much heavier than a 80 shortbox truck.I just got a 454 and was debating which truck to put it in,it will be a go fast motor,no towing etc.
blazer2007 is offline   Reply With Quote
Old 05-22-2007, 10:54 AM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: is blazer much heavier than p.u. ?
i think my truck says it wiegh in at at 2900 it an 86 2wd long bed. I could be wrong it might be the gvw.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 05-22-2007, 05:24 PM   #3
chevroletman19712001
chevroletman19712001's Avatar
i dont think that can be right my 85 camaro weighs 3100 and i know my 79 c10 has to be heavier...
71 chevy longhorn 1 ton
79 chevy straight 6
79 burb 454
91 silverado 350 TBI
and a few others that my brand loyalty wont permit me to post. Eureka Boys!!!!
chevroletman19712001 is offline   Reply With Quote
Old 05-22-2007, 05:42 PM   #4
swb85
On a budget like Fred Sanford
swb85's Avatar
A short bed c10 will tip the scales between 3800-4200lbs, depending on options. Usually right around 4000 is the norm. Not sure how heavy a blaze is.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 05-22-2007, 05:43 PM   #5
SSC's76
No No
SSC's76's Avatar
I get different weights on my truck every time I go to a scale so it's hard to say exact weight. A blazer will be heavier even in 2wd form. The shell adds a couple hundred pounds. Sliding windows weigh more then standard non sliding also you have a tailgate with glass in it and the structure of the blazer from the drivers seat back is different. A good guess would be a 1000 pounds more weight then a standard pu.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 05-22-2007, 06:21 PM   #6
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I would say somewhere around the low 4000 pound range.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-22-2007, 08:26 PM   #7
knightlife
Dark Heart Motorsports
knightlife's Avatar
my lwb weighs in at 4280, just went and weighed it for ya
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 05-22-2007, 09:38 PM   #8
tvblazer78
Low & Fast!
tvblazer78's Avatar
I weighed my Blazer about 2 or 3 years ago, it was about 4800.. And I was running 1/8th at 8.3 at the drag strip.. I had some mad Ford Mustang at me. Sorry I had to put that in too...
tvblazer78 is offline   Reply With Quote
Old 05-22-2007, 09:47 PM   #9
bigblock73
yeller
bigblock73's Avatar
2wd Blazer = 4151 curb weight
2wd swb (fleetside) = 3803
2wd swb (stepside) = 3835
The Big 10 (HD suspension) trucks weigh slightly more.
bigblock73 is offline   Reply With Quote
