Location: Bondurant, IA but in Worcester, MA for school
Does any one know anything about these things? It sounds like a good idea. I have a 1970 C-20 Camper Special and I have no idea wether it would fit or not. If it does what it says i definatly wanna get one. Thanks
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
It does EXACTLY what it says it does. However, In 99.9% of cases, especially if you drive a lot on the street or the drag strip, you'd be better off with a limited slip. The ARB is an excellent unit expecially well suited to the off-roader.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
So you would not recomend it for a daily driver truck that likes to burn rubber and put those little imports to shame from time to time?
Mike,
I thought the point of an ARB Air Locker was that it IS a limited slip when switched off, and a locker when switched on? To me this would be PERFECT for a daily driver / weekend warrior. Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
Suburbans RULE!
The ARB Air Locker is completely locked, like a spool when engaged and completely open when disengaged. They are very expensive like Mike C mentioned and probably more suited for the off-roader.
------------------ 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, Scat crank, H-beam steel rods, KB Pistons, Speed-Pro Moly Rings, Clevite bearings, Speed-Pro High Volume oil-pump, Comp Cams 254H 4X4 Xtreme cam, SR Torquer 2.02/1.60 heads, Comp springs, Trick Flow pushrods, Comp Roller Rockers, Edelbrock Performer RPM intake, 3310 750cfm Holley, Summit HEI, MSD 6AL, Built TH350 Transcat Supper II shift kit 2000 RPM Stall, 4" Rough Country Lift....etc.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
The ARB is an open diff when switched off and it is a spool when switched on. Zero differentian or 100%. NOT what you want in a streeter. Go with a limited slip for the street. I like the EAton, but the Trak Lok or Power Lok (4 pinion) is excellent if you have a Dana 60.
Mike,
My bad. Sorry. I don't want to confuse anyone on the board. I retract my uninformed statement. Darren
its all about the +6 inches
Here is there site. http://www.arb.com.au/arb_air%20locker.htm
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
