Old 05-22-2007, 05:35 PM   #1
eedgell
It's the air up here
eedgell's Avatar
Question need help with axle choices
I found a wrecked 71 K20 with eaton rear and 10 bolt corp front. I think I can pick up the whole mess for real cheap, but want to use the axles for a K20 upgrade from my K10. Would I be better off to find a 14 bolt corp and a dana 44-60 for the front as far as parts go? Is the eaton rear and 10 bolt front worth picking up any way?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-22-2007, 05:44 PM   #2
1969k10stepside
Re: need help with axle choices
If its an original 71 K20 it will have a dana 44 front.The only thing different between a 1/2 and 3/4 ton is the rear diff.The front is the same except for the hubs.I think you would be better off with a 14 bolt because of the availabilty of parts.As I stated above,if you really want a difference in the front drivetrain,you need to step up to a dana 60 front axle
1969k10stepside is offline   Reply With Quote
Old 05-22-2007, 06:12 PM   #3
eedgell
eedgell's Avatar
I dont know for sure what is up front, but I know it is not a dana. So I assumed it was corp. The frame on this thing is complete with 4 speed and np 205. It also has the manual throttle option. The cab is smashed on the drivers side and it has flat bed. The frame looked un messed with. I did not spend alot of time looking at it because it is in the mud and I had my 4 year old son with me. Definitely some parts there, but I am looking for axles. If these are troublesome the eaton and what ever the front is, maybe I will keep looking.
Eric
Old 05-22-2007, 07:17 PM   #4
1969k10stepside
I wouldn't call them troublesome but you really aren't gaining much by adding them.A Eaton rear can be a great axle with the right stuff.But,unless you beef up a 44 or go Dana 60 the front isnt being improved
Old 05-22-2007, 09:44 PM   #5
earl87gta
earl87gta's Avatar
I kept my eaton axle i like it and sevral off road guys do you can use some 14 blt parts with the eaton. truble is limited gearinf most are 4:57 and some are 4:10 but hard to find you can by rebuild kits for them now but they are big $$$. Fot the front if you off road it with big tires a d60 is the way to go. if your just looking for better stoping power the 3/4 axles will be ok.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 05-22-2007, 10:37 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
The Eaton axles will last a long time and are tough as a D60 rear, only drawback is you only have 3 ratios availible. Unless you use 14 bolt axles and carrier like Earl said then you can get higher gears. D44 front axles were used in 67-72, so if it's a Corporate 10 bolt it's out of a '73 thru '80's model GM truck.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 05-23-2007, 02:16 PM   #7
1969 GMC
1969 GMC's Avatar
If the diff has little ears on the bottom of it, then it's a 10 bolt. Otherwise, it's most likely a Dana something or other. GM started phasing these in place of the D44's in the late 70's, but all of the 1980's vintage 1/2 and 3/4 ton trucks had them.
EDIT: is the option sticker intact for the truck? Might be worth a look to see if there is a No-Spin (Detroit Locker) mentioned on it for the Eaton. Then I would DEFINITELY grab it.
FYI, the Eaton's are stronger than the D60 rearend. Not sure why exactly the D60 is perpetrated as being a stronger rear, it most certainly isn't. I think it stems from the fact that you can still buy gears for the D60, and a lot more ratios than you can for an Eaton, so people think the Eaton is brittle or something. It is the predecessor to the 14 bolt, I think they are about equal in strength, and as far as Dana axles go, they are comparable to the D70.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-25-2007, 12:29 AM   #8
eedgell
eedgell's Avatar
Thanks guys. I think I will wait for a later model one ton and grab the 14 bolt rear, and the dana 60 front. Direct install with no cut and paste. Better parts supply as well.
Eric
Old 05-25-2007, 12:36 AM   #9
eedgell
eedgell's Avatar
The only bad thing about this find was that I tried to buy the whole truck, but since it was in a local scrap yard, they could not or would not sell the truck to me compete. The other thing was it was in line to be crushed!!!!! No saving this one!!!! 350, SM465, NP205, Eaton rear, 10 bolt front, Factory manual throttle.
Eric
Old 05-25-2007, 08:09 AM   #10
msgross
msgross's Avatar
you could buy the drivetrain though.... Good guts their to work with...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
