Old 05-22-2007, 09:44 PM   #1
wpvtx
wpvtx's Avatar
Toneu covers for stepsides? DIY?
Any one got any ideas about toneu covers for step sides? Theres noway that my wife will let me spend 1400 for a hard cover - anyone made there own?
Got pics - thanks
1970 Chevy K10
350 CID with 4 speed
4" lift with 86 Dana 44
Front disk brakes
Electric fan/Internal regulated Alt.
wpvtx is offline   Reply With Quote
Old 05-23-2007, 11:10 AM   #2
Jonce
Jonce's Avatar
Re: Toneu covers for stepsides? DIY?
You may want to check this site out http://www.checkerpro.com/index.html
I haven't ordered anything from them yet, but I have my eye on a soft tonneau cover for my 71 GMC step
__________________________________
1971 GMC Stepside
350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar
Jonce is offline   Reply With Quote
Old 05-23-2007, 11:22 AM   #3
cdowns
cdowns's Avatar
check with a local upholstery shop or if you have boat canvass shops they are also good to try
Old 05-23-2007, 11:25 AM   #4
68Stepbed
68Stepbed's Avatar
I was going to suggest the same website Jonce metioned. A freind of mine built one for his 51 GMC a couple years ago. I was gonna build one for mine, but never got around to it.
He basically built a table out of 2x4's then put a sheet of 1/4" luan(sp?) on top, then stretched and glued a peice of vinyl over the top and sides. His didn't cost him much because he used 2x4's he had left over from another project, the vinyl came from a tonneau cover from his dad's old Ranger, and the 1/4" luan was the biggest expense.
Jonce, Did you ever get your carb straightened out?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-23-2007, 01:00 PM   #5
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
That site won't open for me- lots of 404 errors.........
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 05-23-2007, 01:38 PM   #6
67chevemall
67chevemall's Avatar
I made one from a soft cover from a 2001 dodge ram.
The kind that snap on a frame and then clamp to the truck
I made the outside frame from a hardwood (old coat rack) with the Dogde plastic part on the bottom of the wood.
Then I hammered the ribs from the dodge ribs so they where rounded down on the ends and cut to length.
Then I attached all the ribs with small bolts
Then I streched the vinal over it all the stapled it up on the underside to the wood and cut the vinal to size.
The corners were tricky but I cut them close and added a dab of crazy glue on the underside to keep em tight.
Then I put a SS hidge on the Bed Header
The back stayed down with a divers weight tied to each back corner.
Worked great till a light fell on it and ripped it
The frame I scrapped on the last metal run
Cost $5.00 plus free Ram cover ( can get them cheap)
Lucked out my buddy bought a rear cab and was tossing it out
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-23-2007, 01:45 PM   #7
67chevemall
o ya ya'll like the pics
lol
