Old 05-22-2007, 11:21 PM   #1
kawahawk
Junior Member
kawahawk's Avatar
grant steering wheel/horn problem
Here's my problem. I installed a grant steering wheel on my 72 following their instructions. when i went to rehook the battery cables the horn was on. I thought I would just unplug the connection to the horn button and figure it out tomorrow. no dice horn still stuck on even with horn button unhooked. I have come to terms with the fact that I am incompetant with a wrench but I thought I could handle a steering wheel. any suggestions on what I might try??
kawahawk is offline   Reply With Quote
Old 05-22-2007, 11:21 PM   #2
Slammed70
Slammed70's Avatar
Re: grant steering wheel/horn problem
Your truck has a horn?
My 70 dont
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 05-22-2007, 11:24 PM   #3
kawahawk
Junior Member
kawahawk's Avatar
yep and it worked with the old steering wheel!
'72 Cheyenne K-10 LWB
'05 Jeep Wrangler Willy's Edition
'07 Victory Vegas
'99 Subaru Legacy SUS
Old 05-23-2007, 12:26 AM   #4
e rock
Time to pull it all back off. Maybe you got the horn wire pinched (& grounding out) in there somehow?
e rock is offline   Reply With Quote
Old 05-23-2007, 08:57 AM   #5
Mudder
Mudder's Avatar
Hey don't let it discourage ya. Many have had trouble with those.Mine works sometimes and sometimes it doesn't.
Mudder is offline   Reply With Quote
Old 05-23-2007, 09:07 AM   #6
ChevyDude
I/we/Me and Larry...put mine on and my blinker cancelation is all jacked...just a bump in the road...try it again...you'll get it!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 05-23-2007, 10:43 AM   #7
cdowns
cdowns's Avatar
pretty common with grant products . if you get it working correctly they usually have a life span of about 7minutes
Old 05-23-2007, 11:02 AM   #8
Mudder
Mudder's Avatar
They do have nice looking wheels............
Old 05-23-2007, 11:13 AM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I have a LeCarra I'm about to install on my truck, can I expect horn problems too?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-23-2007, 11:17 AM   #10
barn9
Half a bubble off!
barn9's Avatar
Believe me, you're not the first to have problems with a Grant horn kit. I never did get mine to work, even after going through two kits. Like I've said before, with Grant, the horn won't blow, it sucks!
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 05-23-2007, 11:24 AM   #11
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
This isn't very encouraging folks. My horn hasn't been hooked up since I got the truck and I was thinking about getting it working soon. I figured there was a reason it wasn't hooked up after the Grant wheel was installed.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-23-2007, 12:09 PM   #12
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
I had the same problem installing my stock steering wheel .... so I don't know if Grant is the blame here or not. In the pictures the nylon screw retainer goes into the horn bucket and the contact plate fits on the rear of the bucket. Below this is a nylon part that holds a spring which makes the contact when you press your horn button. It is important that the bucket can swivel once the horn ass. is complete other wise you will be in constant contact and the horn will sound and not shut off.
Check yours out .... take the horn button off and press on the bucket and see if it swivels. If it does not swivel you are in constant contact. Disassemble and reassemble.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 05-23-2007, 12:40 PM   #13
wedgemon
wedgemon's Avatar
Don't forget the easily lost foil contact sticker. Without that you need to tape the end of the horn wire and not use the horn. They work good when done right. BTW the foilr sticker instructions are vague or non-existant in many Grant install kits.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 05-23-2007, 12:50 PM   #14
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
My grant wheel still works correctly after several years. There is something pinching the horn wire. Should be a simple fix once you have the wheel off and can see what happened. The pinch point should be obvious in the wire if it is pinched hard enough for constant contact.
You'll get it just fine- just take it back apart and look carefully.
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 05-23-2007, 04:43 PM   #15
Orange
Licensed to Thrill!
Orange's Avatar
Wow - I must be lucky.
My Grant horn works fine. Has for at least 8 years now...
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 05-23-2007, 04:52 PM   #16
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Mine WAS working fine and then all of a sudden it started honking while making a turn????? I need to get in there and check it out. Other than this time I've Never had a problem with it
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
