![]() Join Date: Nov 2006
fuel level gauge problem
my gas gauge stays on full. anybody know the proper checkout routine for trouble shooting the circuit-gauge etc . ?
bob in tn. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: fuel level gauge problem
This may help.
http://www.6066gmcguy.org/Electrical-02.htm
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Try Disconnecting The Wire At The Tank And Shorting It Out. If The Gauge Moves You Have A Bad Sending Unit. If It Does Not Then The Problem Will Be In The Gauge. Check You Power Source!!!!
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan Last edited by 72BLUZ; 05-23-2007 at 11:20 PM. |
thanks alot just what i needed.......
bob |
make sure the tan wire is plugged in here:
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
That Brown Wire Is Missing In Action ........ Its Also Missing From Sending Unit ...... Homer Has Been Working On This Truck It Seams.... All Your Help Is Very Appreciated. Wire O Wire Where Art Though.
Bob |
Just run you are wire from sender to the fuse panel and plug it in.
