Old 05-23-2007, 11:03 PM   #1
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Borgeson parrt numbers?
Can someone give me the part numbers of the u joints to build a steering shaft using Borgeson or Flaming river parts?
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 05-25-2007, 07:02 PM   #2
BLAZERMAN
BLAZERMAN's Avatar
Re: Borgeson parrt numbers?
Nobody has done this?
Old 05-25-2007, 08:47 PM   #3
snj8198
snj8198's Avatar
I seen your post a few days ago but sorry I guess i threw my reciept away. I'm running a borgesson collapsible shaft with needle bearing u-joints. If I remember right the box joint is a 36 spline but I don't remember the box shaft size, and the top joint is a 1" Double D connected to a Flaming River 30" brushed tilt column. The steering is tight and smooth. Borgesson can build anything you want as probably seen their web site. -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 05-26-2007, 12:03 AM   #4
BLAZERMAN
BLAZERMAN's Avatar
Thanks steve, I was thinking about building one fromparts I've seen on Ebay but it might be better to just give them a call. I usually end up spending more trying to save money.
Does yours have a vibration damper in it? I've seen them come both ways but have heard that you get alot of "road feel" without one.
