Cereal Killer
Drop spindles
Looking for a set of 2 or 2 1/2 inch drop spindles for a 87 c-10 with 1 1/4 rotor. Planning on running 7" (I think thats what they are) rallys and dont want clearance issues. What brand spindles, what kind of price and where is the best place to get them?
If I dont do it....somebody else will. |
Re: Drop spindles
I just bought some 1" spindles for the 87 front crossmember Iput in my 66 and they were from Early Classic Enterprises. 199.00 plus shipping! Your going to want new aftermarket brake hoses- the original 87 hoses didn't fit without tweaking the metal tubes on the hoses.
The 73 front suspension I put in the 67 accepted the stock brake hoses with no problem on the western spindles that I bought from ECE 5 Years ago. ECE has the best price I could find, I have always gotten great service from them. ![]()
Scott 66 chevy short step 327 4speed 67 chevy Short Fleet tpi 350 700r4 72 chevy K10 swb 01 GMC Sierra 01 Pontiac Bonneville |
yeller
Re: Drop spindles
shade67, 1" drop spindles?? I have only seen/heard of 2.5 and 3".
![]() onetonk5, Rallys came in 7 and 8 inch widths. You can run 2.5 or 3 inch spindles with the narrower Rally wheels, if you want to run 8 inch Rallys, then you will need 2.5 inch spindles. You can also trim your LCA if you want to go down with a 3 inch spindle and run the 8 inch Rally...I have done this along with many many other people.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 05-28-2007 at 01:15 AM. |
#4 | |
![]() Quote:
A guy with a truck
Re: Drop spindles
7" rallies will give you no problems. 8" is where you run into rubbin' problems. My truck runs 7s in front 8s in rear...
ECE or Belltech. Gonna be about $250 either way. Any cheaper and you get no-name cheap casting junk that will break. I think I saw somewhere you were switching to 73-87 stuff up front. If that's the case, go with Belltech. Get the 1 1/4" HD rotor version. Even if your stuff is not HD, it is cheap to upgrade. Rotors and calipers are like $12 each at the local parts store...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
yeller
Re: Drop spindles
I believe he would need new bearings too to go with the new rotors...but I am not 100% positive...I'd check to be safe.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#7 | |
Re: Drop spindles
I am planning on running 7" front and 8" rear and am still a bit lost on where I need to be size wise. Many thanks! Last edited by Shane; 05-29-2007 at 09:41 AM. |
Re: Drop spindles
Shane..... 15" wheels or ??
Re: Drop spindles
15" x 8" & 15" x 7" rallies on a bagged truck
Re: Drop spindles
215/75-15 is 27.7" tall ; 6.5" van ralley is ideal width
225/70-15 is 27.4" tall; 7" rim is ideal 255/70-15 is 29" tall; 8" rim is ideal I ran the 215/75/van ralley & 255/70/8" truck ralley combination & thought the wheel/tire combo was just right for >4/6 drop.
#11 | ||
A guy with a truck
Re: Drop spindles
I've got 255/70s all the way around, but would prefer a smaller front. My Blazer had 245/60 fronts and they were too short with drop spindles... kept dragging the a-arms.
Re: Drop spindles
tell me more about these "van" rallies ... never knew there was a 6.5" rally ... are they pretty easy to find?
#13 |
Re: Drop spindles
Yep, there fairly easy to find. They came on the full size GM vans since the late 70's & are identical in appearance to the wider truck ralley. Mine were stamped 6.5" w/a dbl letter code just after.
#14 |
Cereal Killer
Re: Drop spindles
Ordered a set of 2.5" Western Chassis drop spindles today...221 plus shipping. Have a few buddies running the same spindles and like them very much. Thanks for all the replies
Mark
#15 | |
Re: Drop spindles
![]() http://cgi.ebay.com/ebaymotors/73-87...spagenameZWD1V |
#16 |
Re: Drop spindles
be careful you might end up spending some time in solitary
#17 |
Re: Drop spindles
you mean in here! oooooohhhhhh scaaaarrrryyyyy.
#18 |
Re: Drop spindles
Thanks Scotti! I have a complete set (4) of the 8 inchers and a complete set of 7 inchers. I would like to find me a couple of the 6.5" too.
I have decided against putting my 18" Billet Specialties wheels on until after the truck is painted ... which may be never. ![]() Not really "ol skool" ... more "Bo Duke redneck skool." ![]() I looked at a 255-70-15 tire today, and like the looks of it ALOT, but I am concerned I will have a rubbing issue on the inside of the rear fenders on the stepside bed. The fenders (if viewed from the rear) taper in towards the beside as you follow it up and I think (dunno yet) once the bags are dumped, the tires will rub the inside of the fender. Just so happens, my dad has a set of 255-70-15's mounted on a corvette rally style wheel and once I get the bed re-assembled, I should be able to see if this tire is going to rub or not. Taking the bedsides, fenders, tailgate and cross sills to the guy who's gonna do my media blasting for me tomorrow. Hope to have those back by next weekend so we can do some assembly work and see if these tires are gonna work or not. I am sure hoping so after seeing them on the wheel. Nice and "meaty." Thanks again for all your help. ![]() Last edited by Shane; 06-01-2007 at 06:19 PM. |
#19 |
Re: Drop spindles
The 255-70's fit just right on an 8" rim & you shouldn't have rubbing issues w/the stock 4" back spacing.
A 225-70 on a 7" rim up front would work well but I liked the way the 6.5" van ralley helps tuck the front track width. On my 68 I noticed the track width is wider once you add disc brakes vs. the stock 68 12-bolt rear. I can't stand to have the front wheels farther apart than the rears (it just doesn't look right to me).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-01-2007 at 07:04 PM. |
