The Original HotRod KnifeMaker
![]() Join Date: Jan 2007
What rear end ratio for Big Block on Freeway?
Big Block guys, what rear end are you using with factory size tires to cruise the freeway comfortably at 70 mph?
Thanks,
Dave 69 GMC SWB 2WD 454 Turbo 400 |
Re: What rear end ratio for Big Block on Freeway?
Gear it tall and use your big block grunt!! Start with 3:08 and get an overdrive if you can find one. I have seen big block passenger cars with 2:76 ratios stock from the factory.
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
Active Member
Very curious on this one as well. I've got a 454 out of an 81 dually goin in my 67 with a th400 and a GV overdrive. I want to have that BBC torque fun, but at the same time be able to drive it to work (40min one way) occasionally.
so keep the suggestions coming. good thread WinDancer
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
I'd attack it with math.
Figure what minimum RPM is most efficient for your engine/cam/exhaust setup to turn at (let's assume 2200 for the moment). Measure the diameter of the tires you have and figure the circumference (I'll assume 30"). Then determine the high gear ratio through the tranny (I'll assume it's a TH400 that has a 1:1 high gear whose converter can't lock-up so the ratio through the tranny is about 1.03:1 because it slips about 3% at highway speeds). Take the speed in miles/hour (70) and divide by 60 to get (1.17) miles per minute. Then multiply that by 5280 to get (6160) feet per minute. Next, divide that by 2200 to get the number of feet your truck needs to move per engine revolution (about 2.8 feet per engine revolution). Now take the rear tire diameter in inches (30) and multiply by 3.14 to get its circumference (94.2"). Then divide that by 12 to get (7.85) feet. Now divide the tire's circumference in feet (7.85) by the number of feet your truck needs to move per engine revolution (2.8) to get the total driveline reduction needed (coincidentally about 2.80). Next, divide the total driveline ratio needed (2.8) by the tranny ratio in high gear (use 0.7 if your tranny is a TH700 or TH200, 0.8 if it's a late model manual with overdrive, or 1.0 if your tranny is an older manual or an automatic Powerglide/TH350/TH400). Assuming you have a 1:1 tranny ratio, 2.8 divided by 1.0 means you'd need a 2.8:1 ring and pinion. If you have the 0.7 overdrive, then 4.0:1 is about right. Since there isn't a 2.8:1 (or a 4.0:1) Chevy R&P option, you'll have to choose either a 3.08 or 2.73 (or 3.73 or 4.11 if O/D tranny) depending on your needs/preferences. If your tires are smaller than 30" in diameter, then the 2.73 (3.73 for O/D) may well be the better choice. If the tires are taller than 30" and/or if your engine needs to turn faster that 2200 to be efficient, then the 3.08's or even 3.23's (4.11 for O/D) may be the better choice. You do the math using your own real numbers. You should get similar results. Now that the "top end" is set, think about the bottom end. 2.73's will yield great mileage, but are going to take off very slowly from a traffic light or when pulling a heavy load. You may want/need a tranny with a lower (numerically higher) low gear. If so, rerun the math above with the new tranny ratio figures. For example, a TH700 has a 3.06:1 low gear and a 0.7 high gear. That combo with a 3.73 R&P and 28" tall street tires should offer offer you the best of both worlds. One thing to watch out for though. "If" it's an automatic, you don't want the engine RPMs to be running slower than your torque converter's stall speed (unless it has an electric lockup function and it's enabled). Otherwise you'll cook the tranny.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe Last edited by mnunn454; 05-24-2007 at 07:43 AM. |
Junior Member
WOW! Can you say that again?
Keith |
Active Member
454 w/ 3.08, TH400, 255/70-15 tire about 29.1"
@50 MPH, RPM is about 1775 @60 MPH, RPM is about 2150 @70 MPH, RPM is about 2500 @80 MPH, RPM is about 2850 I believe the general consensus is that the closest factory tire equivalent is a 235/75-15 about 28.9" so this is a fairly good camparison between the two tire sizes, RPM would be off by a negligible amount with the slightly smaller tire by 15-30 RPMS.
"The Great State of Florida" Last edited by KFreddy; 05-24-2007 at 09:59 AM. |
I have a set of 2.92's I can sell you
its all about the +6 inches
hey mnunn454... were you using a cheat sheet or anything for that?
I only ask, becouse that's impressive for a normal car guy to know, let alone put into aplication, mathc like that. Hell, you had be confused after the first couple lines. |
WOW is right but I expected nothing less from this board.
You guys are terrific with info and sharing your knowledge! mnunn454, thanks for the info. Anyone know what the stall speed is on a regular th400? I have noticed that if you let off the gas that the transmission kind of floats off somewhere and isn't a solid lockup like with other vehicles I have owned. Is there a way to just have it engaged all the time or does that require a tranny change? Is there a way to check for the electric lock-up function? Jim_PA is that a standard ratio for our trucks? If so and it is in good condition can you get a shipping cost to 98589 and PM me with it? Don't want to be doing business in this thread. Thanks again,
your truck does not have a lock up converter... so the drop in RPM that you describe, is normal.
You ask for standard ratio.... what engine/tranny did your rig come with originally? That dictates the ratio. |
#11 | |
![]() Join Date: Jul 2005
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
Thats the Hillbilly way
I'm running a Dana 60 with 3:54 and 265/75/16 tires .No problem on the Kali freeway doing 70 .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , Last edited by Bill72BB; 05-24-2007 at 03:19 PM. |
#13 |
#14 | |
How do you know it doesn't have the lock up converter? Because of the freewheeling? The other suggestion was to check the wiring for it? So maybe I do have one and it isn't wired in? Where do you guys get all this stuff in your heads? I am 58 and seems like I lose access to a little more info every year ![]() Thanks!
#15 |
I did a search of these forums and came across this article which explains torque converters and stall speeds so well I even understood the theory
![]() http://www.hardtail.com/techtips/sel...converter.html
