![]() Join Date: Jun 2002
painted dash reflection?
I have heard that if the dash between the dash pad and windshield is painted gloss, will reflect a glare into the windshield. Is this true? And if so, any sugestions??
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
Keepin' It Stock
I hear this too, so I painted mine flat black but it was really hard to keep looking nice (always dusty) and it wore easy. I went back to a satin black - looks much better and is easy to clean. Haven't had any problems with reflection but that's probably because it's black - may be a problem with other colors.
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
its all about the +6 inches
If you are going with a base coat/clear coat, you could just not shoot the clear on the top of the dash.
I don't know how they did it back in the day, but it does seem they are all painted with flat paint. |
thanks for the replies, I already shot the interior, so I guess I will sand the dash with some 1200 grit to flatten it.
Half a bubble off!
I did mine in satin black also, no glare, no dull.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
just pick the color you want to use and have your auto paint store mix it in a "vinyl" color.It can be the same color of your vehicle even if that's what you want.You can get the vinyl mixes in a variety of sheens low gloss -med gloss-high gloss or any in between.Most vinyls are ready to spray once mixed at the shop and have indefinite shelf life"supposedly". On my trucks I usually paint the top of dash to match the pad-it's the same paint holds up great against sun fade too.
Seņor Member
I did mine with a $4 can of spray-on bed liner material. It's made by Dupli-Color and can be had at your local Wally-World (aka Wal-Mart). It's got a modest sheen so you don't get reflections, but it doesn't look 'dull' like flat or satin can because it's got a slight texture to it. I'll post a pic or two when I get a chance.
Kenneth
Progress = 0%
Mine used to be base coat/clear coat white and there was a bad reflection on the winshield. I guess it didn't bother me too much because now it's painted turquoise base coat/clear coat
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
Seņor Member
Here are some pics of the old (current) cab dash...
Kenneth
Seņor Member
and...
Seņor Member
And of the new cab's dash done with the Dupli-Color...
that dupli-color looks great ,thanks for the idea XXL
#13 |
My painter did mine as Longhornmail suggested, and painted the topside of the dash in just base coat. Same color as my truck, and no glare. Just thought ya might wanna know? Here's a pic of the front of the dash.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
#14 |
And here, you can see the top of the dash. (kinda)
