Old 05-24-2007, 03:11 PM   #1
66newbie
Brake conversion kit
looking for a front drum to disc conversion kit that would work with my 66gmc. I seen a few online, but want to know if anyone has already done one, looking for the power brake option also. thanks in advance.
66newbie is offline   Reply With Quote
Old 05-24-2007, 05:38 PM   #2
64GMCHorsepower
Justified!
Re: Brake conversion kit
I just took mine off a '72 GMC truck, and swapped it over.....
Bought some new lines, and a prop valve, and good to go.....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 05-24-2007, 06:30 PM   #3
Jonboy
Slots go on anything!
71-87 GM truck.
Old 05-24-2007, 07:51 PM   #4
1restorick
1restorick's Avatar
I did the Early Classic Industries Kit. Top notch!!
http://www.earlyclassic.com/
Rick
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 05-27-2007, 01:20 PM   #5
66newbie
64GMCHorsepower When you say swap, is that from the spindle on out or I think I read in one of the threads it was also the control arms?
Jonboy you saying that I can swap with any 71 -87 GM truck?
Thanks 64GMC, Jonboy, and 1restorick.
Old 05-27-2007, 09:04 PM   #6
64GMCHorsepower
Justified!
I actually swapped the whole front crossmember.....
But you can do just the control arms.
Chad
Old 05-27-2007, 09:13 PM   #7
RojoLoco
For my '66, I took the whole shibang from a '78 C-10, The truck had been rear ended, so we just cut the frame off at the cab and took everything forward of that, minus the power steering box, he had already sold that. It all bolted right in. One thing I liked is that the U-bolts that hold the lower control arms on the later crossmember are alot beefier.
Project: 1966 Chevy C-10 short step-side. 512 Caddy, 10:1 pistons, 76cc heads with oversize valves, Shaft rocker system, MT-10 cam, Edelbrock intake, BBC headers with fabbed Cad flanges.
RojoLoco is offline   Reply With Quote
Old 05-27-2007, 09:51 PM   #8
laidout
Active Member
laidout's Avatar
if you where closer id sell you the complete crossmember disk to disk for a 100.00 im in oklahoma
laidout is offline   Reply With Quote
Old 05-27-2007, 10:32 PM   #9
66newbie
Thanks for the info all, I'll start looking
Old 05-29-2007, 10:39 AM   #10
62chevy302
hillbilly
62chevy302's Avatar
i found a boy with a 85 is there anythng different besides the metric but it dont matter if i have every thing right?
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 05-29-2007, 05:28 PM   #11
jchav62
1962 C-10
jchav62's Avatar
Are you planning on keeping it 6 lug? If so, you'll need to buy the six lug rotors from one of the catalogs and you'll be able to use some spindles for 71-87. If you plan on converting to five lug, you can use the spindles and rotors. You just have to swap out ball joints, I believe. I helped my brother in law a couple months ago install one of these set ups. Worked real nice on his 67.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-29-2007, 11:09 PM   #12
62chevy302
hillbilly
62chevy302's Avatar
i havent made my mind up if 5 or 6 lug if i stay 6 lug can i just get 6 lug rotors and use the same calipers.
-1962 C-10
Old 05-30-2007, 12:04 AM   #13
55dude
55dude's Avatar
if your doing 5 lug 73-87truck,73-91 2wd burb'. 6 lug use the 88' up all the info is in tech archive on this site. good luck.
55dude is offline   Reply With Quote
