BAD BOW-Silverado XST
A-arm shaft alignment.
Okay, which way do the dimples face? Are they used to mark the location of the U-bolts? I marked the location then sanded down the shaft for painting.
![]() Is there a trick to realign the lower arm? |
STILL PLAYS WITH TRUX
It's been awhile since iv'e had mine off but as i recall there are two dowl pins in the x member and the shaft engages into them and i thought they would only install one way.
But if not then i would say it wont make a differance. |
Re: A-arm shaft alignment.
Yea you're right. I went blank when the shop called and asked which way should the dimples face. I'm going to measure a rough angle and tell them turn them. The upper arms face a certain way too. I'll have to look closely. I'll post pics of the new bushings tomorrow.
Crew Cut
you can turn them with a strap wrench, wont scar the metal
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
Actually if ya leave the nuts loose on the ends of the shaft you can trun them to the point you need them at to bolt them back on and then hook them up to the spindel and set it on the groung and then tighten the two shaft nuts cuz if you have too much preload on them the rubber will just rip apart in no time.
Until Seventy Times Seven
g-
Here's a couple of pics showing the alignment of the dimples with respect to the LCA (just before the install) and the position of the UCA. I agree with 87STEPPER, I left the shaft untightened until I installed it and had it pre-loaded.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
Thanks for the pictures. I'll bolt up everthing next week. I need order the rubber stop mounts for the lower a-arms. I destroyed the old ones while trying to remove them.
The a-arms now have the new bushing pressed in. I've uploaded the pictures.
http://rides.webshots.com/slideshow/558979771ceNHXA The new pictures start from here ![]() |
It Is What It Is,,,,
WHOAaa,,, very nice!!
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
67 Chevy Stepside
looking good
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
Goog progress, G.
Reminds me of my rebuild minus the paint... especially this pic of mine:
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 05-28-2007 at 01:44 AM. |
