Old 05-24-2007, 09:48 PM   #1
Lated
Lated's Avatar
I smell GAS!!
I just replaced the in cab fuel tank on my 70. Now I smell gas sometimes when I first get in the truck. It's only in the afternoon on warm days after it's been sitting in the sun all day, never in the morning when it's cooler. I pulled the seat out yesterday and checked for leaks but couldn't find any. This coupled with only smelling fuel in the afternoons leads me to believe that the tank just isn't vented properly. Is there anyway to vent the tank or do I just need to buy a new gas cap?
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 05-24-2007, 09:54 PM   #2
Orange
Licensed to Thrill!
Orange's Avatar
Re: I smell GAS!!
Just a note, I smell gas too.
My tank is the 1971 version, but it presents the same exact problems you describe.
My guess it is something to do with gas being shut up in a cab all day in the hot sun. The vapors are just going to present. I have never really noticed it before, but I never DD it before either this much in the hot months.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 05-24-2007, 10:05 PM   #3
lbpd719
Zappaphile!
lbpd719's Avatar
Re: I smell GAS!!
here's a question (and kind of how I fixed my version of the same problem. How are all of your filler neck seals, including your cap. Do you get a large inrush of air when you remove your cap, and is your cab to filler neck seal in good shape.
When I first got my truck, I went through the same hunt. after sealing up the rubber on the cab and changing the cap, problem was pretty much solved. I can still smell a little fuel on occasion, but not like I could before..
Good Luck
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 05-24-2007, 10:12 PM   #4
Lated
Lated's Avatar
Re: I smell GAS!!
When I replaced the tank I replaced everything up to the fuel pump, sending unit and grommet, fuel line, filler neck grommet and the filler cap all because the tank was naaasty! I had to clean the fuel filter at the carb once a week so the engine could get enough fuel to run. I didn't smell gas before the tank swap but that could be because there were two 1/8 inch holes drilled in the filler neck outside the cab either to vent the tank or because there was a chain at one point attached to the cap so it wasn't forgotten. The new cap is locking but I haven't pulled the cap off when I could smell gas in the truck. I'll pull it off tomorrow afternoon and see what happens.
Old 05-24-2007, 10:16 PM   #5
mrein3
mrein3's Avatar
Re: I smell GAS!!
I believe in 1972 GM went to a non-vented cap. Your locking cap may be that style. I don't want to be responsible for somebody stealing your gas but you may want to try a stock cap.
If it is not vented, and it heats up in the sun, those fumes have to go some where.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 05-24-2007, 10:17 PM   #6
67_C20Pres
New Member
67_C20Pres's Avatar
Re: I smell GAS!!
Same problem with my 67'. When I replaced my seat I noticed a port @ the passenger side on the top of the tank. Looks like a return line or vapor recovery port. But mine is just kind of capped off. I'll need to dig more on the fuel setup.
Suggestions for the other posts are: Check the fuel sender O-ring & fuel pump connection for leaks. My has a short section of rubber fuel line between the sender and the line and it was leaking. That helped some but the vent, in my case, is probably the key. As vapor pressure increases due to heat, it has to go somewhere and I suspect that there was a recovery setup at one time. Or it's the wrong damn tank.
Steve
67' C20 - Newest - My junkyard dog and work in progress
67_C20Pres is offline   Reply With Quote
Old 05-24-2007, 10:26 PM   #7
sick69
sick69's Avatar
Re: I smell GAS!!
On the passenger side of the tank on the top there is a vent tube,,,,where does it vent to? seems like it just vents into the cab.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 05-24-2007, 10:30 PM   #8
67_C20Pres
New Member
67_C20Pres's Avatar
Re: I smell GAS!!
Frank
Yeah, another fine cobble job by the previous owner. It's topped off with a yellow wire nut and electrical tape. Positive seal, I think not! HEHE
Steve
Old 05-24-2007, 10:42 PM   #9
sick69
sick69's Avatar
Re: I smell GAS!!
Well there is a good place to start for removing the fuel smell lol
70 chevy lwb c10
Old 05-24-2007, 10:47 PM   #10
Lated
Lated's Avatar
Re: I smell GAS!!
I don't have a vent on the passanger side. It's gotta be the cap not venting.
Old 05-25-2007, 12:21 AM   #11
whitelightenin69
whitelightenin69's Avatar
Re: I smell GAS!!
had the same problem on my 69 when I changed to a locking cap, I just cut a small hole in the rubber seal on the cap, problem solved.
whitelightenin69 is offline   Reply With Quote
Old 05-25-2007, 12:23 AM   #12
dan42
dan42's Avatar
Re: I smell GAS!!
Sometimes I smell gas too - even though my tank is under the bed. Usually after I've eaten something foul.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-25-2007, 12:59 AM   #13
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: I smell GAS!!
i smell it to now and the vent tube doesnt go anywhere exept up the cab corner and back down, its not a po job its how it came, and ive got the stock non locking cap and no leaks anywhere and really the only times i smell gas are when i get back in after pumping some in at the station and on hot days other than that i hardly ever smell it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-25-2007, 12:59 AM   #14
GREASEMONKEY72
Re: I smell GAS!!
-steven
Alte Seele S.S.
Old 05-25-2007, 12:45 PM   #15
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Re: I smell GAS!!
I had this problem with my 50'. I had to change the fuel sending unit and decided to splurge and bought a new tank to sender seal, this solved the problem.
esll.
The lower the fuel the more fuel vapours are present and tends to smell stronger.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
