Old 05-25-2007, 10:17 AM   #1
Joe T
installing floor shifter
i am installing a floor shifter tomorrow and was wondering what kind of saw i should use to cut the hole? i currently do not have my air compressor hooked up, so any air tools are out.
Joe T is offline   Reply With Quote
Old 05-25-2007, 10:22 AM   #2
fun in dirt
fun in dirt's Avatar
Re: installing floor shifter
Could just drill out a hole for a starting point, then cut out whatever shape you need with a jigsaw.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 05-25-2007, 10:26 AM   #3
Joe T
yea, the directions say to first drill a hole, then make it about 2.5 inches in diameter. i guess i should pick up some metal blades if i use the jigsaw.
Old 05-25-2007, 02:54 PM   #4
RustyParts
RustyParts's Avatar
2-1/2" holesaw would work too.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 05-25-2007, 03:10 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
What kind of shifter and what size of hole? That will make this a little easier.
piecesparts is offline   Reply With Quote
Old 05-25-2007, 05:14 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
First check under the truck to see if there is anything in the way that you may drill into.Don't ask how I know this.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-25-2007, 05:22 PM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
...Like the tranny?
My 700R4 is close enough to the floor that using a sawzall or jig saw was out...
I used a cut off wheel for my Lokar Shifter. Makes a nice clean cut. You can also get some nice cuts using a grinder, but it takes longer and be real careful it doesn't get "stuck" on you. I drilled holes in all 4 corners first for a clean cut.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
