05-25-2007, 11:19 AM | #1 |
Straight "6" Shooter
Whats the difference?
On my truck I have the heater controls in the middle of the dash area, they are up and down sliders that control defrost, fan speed, and temp. Ive seen some others that have the controls which look much different under the dash. What is the real reason they did that? I cant imagine how you could make an "economy heater" and not have just a regular heater.
1966 LWB 292 I6 & Granny Low If you listen intently, you can hear a FORD rusting in the distance. My LUG NUTS take more TORQUE than your HONDA makes! |
05-25-2007, 08:50 PM | #2 |
Registered.........
Re: Whats the difference?
Sounds like your truck had A/C, or possibly some one installed A/C controls.
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
06-12-2007, 07:47 PM | #3 |
From what I have seen so far there were 3 different heat/vent setups with 3 different heater cores with out getting into AC. With AC there are even more combinations.
06-12-2007, 09:50 PM | #4 |
On '64-'66 Chevy trucks, there were two heater/defrost options.
The basic unit was called Thrift Air. The control on the dash is a single pull knob that controls the air flow and fan speed. The defrost diverter is on the heater plenum box under the dash. It is a single knob that swings open to divert air flow to the dash vents. The second option is the Deluxe Air heater/defroster. It has three slide levers/knobs, that control the heater, defroster and fan speed. Some trucks came from the factory with no heater and had heater delete plates covering the heater box openings under the hood on the firewall. The '60-'63 trucks were equipped a little different, however I am not familiar with them, whereas I only have '64-'66 Chevy trucks. I hope this helps. Tony |
06-13-2007, 09:33 AM | #5 |
1962 C-10
You say all the controls are 'under' the dash? Sounds to me like an aftermarket A/C-heater setup. I think that most 60-66 heater controls, no matter which setup, are on the dash. I could be wrong though...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
06-13-2007, 01:44 PM | #6 |
jchav62:
You are correct, all factory heater controls are on the dash. Tony |
06-14-2007, 12:21 AM | #7 |
post some pic's
