i solved a few problems!!!(almost)
well since ive had my truck, if i left it to sit for a few days the battery would die. i got my test light out and hooked it between the + terminal and the battery cable, the light was dim but on. i went through the truck pulling fuses and checking wires. for the hell of it, i disconnected the gauge cluster wires, and thats what it was. when i unhooked them the test light went off. i dont know why any gauges would be pulling power when the switch is off but hopefully ill figure it out. also i started it up and was just standing there admiring the sound of a 350 with glass packs
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
Re: i solved a few problems!!!(almost)
also, after i posted this i rewired my headlights/tail lights/blonkers completely including adding a new headlight switch so the high/low is on the switch it self. this is what happens when i get bored.
Hollister, CA.
![]() Join Date: Sep 2006
Don't forget the 'blonker-fluid' needs to be changed on a regular basis......after every other muffler-bearing rotation.
John ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Whew! Thanks, I don't feel so lonely now. I've been telling everyone that my truck is paid for... except for that monthly payment to the local hardware and part store.
dont forget to check your lugnut gaskets and replace if needed
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
