Old 05-25-2007, 03:52 PM   #1
dan42
dan42's Avatar
Vacuum line from carb to?
There is a vacuum line that comes from the base of my carb and goes through the firewal and under the dash - does that assist the heater/ac controls? When I have it hooked up, I hear a hissing noise from under the dash, so I'm thinking I have a hole in the line under there somewhere.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-25-2007, 03:56 PM   #2
BurnoutNova
BurnoutNova's Avatar
Re: Vacuum line from carb to?
not certain, but if your truck has A/C there may be a vacuum reservior to actuate the mode doors, on gm cars atleast there like a 6" ball under the hood, but ive never seen where there at on the trucks
BurnoutNova is offline   Reply With Quote
Old 05-25-2007, 04:29 PM   #3
jhow66
jhow66's Avatar
Just follow the line and plug the end -no hiss -truck will run better (idle speed will slow down when you stop the leak)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-25-2007, 10:00 PM   #4
dwaite72lnghrn
Not sure what year you have but if it is factory air you will see a vacuum resovoir on the airconditioning housing above the passenger valve cover. One end runs to the "T" on the back of the intake manifold and the hose out the other side runs to the vacuum switch "top lever" of the heat/air controls. The vacuum switches can go bad and leak. attached is the vacuum diagram and a picture of a '72 vacuum canister.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
