Gear ratio
Does anyone have an idea as to which gear ratio is in my truck? Its a 71 custom camper with a dana 60.
depends on original drivetrain and the info listed on your spid label, just being a dana 60 does not point specifially to a certain ratio, as 67-72 dana 60 could be 3.54, 4,10 or 4.56
so...... what was original drivetrain in it and what model is it ? model code should be first item listed in the Rh side column |
The model # is CE20934. It had a turbo hydramatic trans and a 350 according to the options sticker.
72 Cheyenne
3/4 or 1/2 ton? 10 or 12 bolt?
3/4 ton. its a dana 60, Are there 10 and 12 bolt dana 60s?
Thats the Hillbilly way
Chevy punk
3/4 ton ,350 engine,auto trans ,leaf springs. Standard was 4.10 rear end . If you have a tack use this link to check the ratio. http://www.prestage.com/carmath/calc_Gears.asp Bill ![]() ![]()
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
its all about the +6 inches
Is it leaf, or H.D. coil?
What is your RPM at 60 MPH...and how tall are your tires? I say pop the cover off the diff, chainge the oil, and count the teeth. |
Thanks for your help. It hasn't ran since i've had it(i'm putting the engine in this weekend
72 Cheyenne
I have a Dana 60 leaf 10 bolt rear, the stock gears were 4.10 or 4.11
Location: Help! I'm in an office park with its own network of freeways!
I was unaware Dana axles had bolt designations like GM Corporate axles.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
nope...designated as dana 60, I think there was a 44 or something like that...ect.
I knew about the differing model numbers. Just never heard of the bolt designation before.
