Old 05-26-2007, 01:49 AM   #1
raiden7800
Straight "6" Shooter
raiden7800's Avatar
Went back original....
I was having problems with my HEI distributor, so I decided to put the original points and condensor distributor back in. Got a good deal on a new unit, 42 for the distributor, 3 bucks for the rotor, and 5 bucks for the cap. Got some new wires as well. Put it together, and realized that I didnt have a coil. So I robbed the mopar coil off of my parts mercedes benz (dont ask... please) hooked that up, and wired directly to the battery. I think I am 180 out on the distributor tho, it acts exactly like it did when I first got it. So, I am going to turn it around tomorrow morning sometime and see what happens.
I also have the spare HEI distributor, which I no longer need. All I got out of her tonight was a big BOOM! So I know that I have spark.
Anyways, I'll update as I make progress.
1966 LWB 292 I6 & Granny Low
If you listen intently, you can hear a FORD rusting in the distance.
My LUG NUTS take more TORQUE than your HONDA makes!
raiden7800 is offline   Reply With Quote
Old 05-26-2007, 08:59 AM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Went back original....
I'm surprized you went back to the points style distributor. The HEI has a hotter spark, and a hell of lot easier to hook up. Good Luck.
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 05-27-2007, 07:49 AM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
ive got the og points and it runs better than a couple of my friends that have HEI
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-04-2007, 06:37 PM   #4
slepysal
slepysal's Avatar
I have a pertronix kit, keeps it looking stock with electroins inside the cap works great !
slepysal is offline   Reply With Quote
Old 06-04-2007, 07:04 PM   #5
LILRED66
LILRED66's Avatar
Good luck with getting her spinning again. I am going to check into the Petronix set-up. I prefer the stock look. Thanks for heads-up.
Tony
LILRED66 is offline   Reply With Quote
Old 06-05-2007, 04:59 PM   #6
baddawg65
baddawg65's Avatar
I really like my HEI. I used one off a late 70's with the coil still seperate from the cap. I used a MSD high vibration coil and going to add MSD 6 offroad when I figure where to mount it. The only problems I've with the HEI conversions is people use the stock + coil wire wich has built in resistor.
baddawg65 is offline   Reply With Quote
Old 06-05-2007, 06:49 PM   #7
LILRED66
LILRED66's Avatar
baddawg65:
I like the looks of your 292. Well done. I see you have an electric fuel pump.
Tony
