![]() Join Date: Oct 2006
Another brake Question!!!
I have a 1969 CST20 parts truck and a newly aquired '68 C10. The 69 has power drum brakes,the '68 has manual brakes. Can I use the master and booster off the '69 on the '68? What about the booster with a disc brakes master? If so, what master would I use for disc brakes? Thanks!
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Dave's not here, man
Re: Another brake Question!!!
I'm not 100%, but I think I've read about guys using a 3/4 ton booster/master cylinder. I think the 3/4 ton boosters are larger and provide better stopping power?? No clue about the booster w/ disc brakes master, though. Maybe this bump will yield some responses.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 05-26-2007 at 08:24 PM. |
ttt
you will need a different master for disks
1969 GMC 910 1970 GMC 1500 custom 1972 yamaha 175 "Money is just like trucks you can never have enough" |
so you have diskbrakes with a manual maincylinder .
i believe if you leave the cylinder on there and put the the booster behind with all the brackets hoses and stuff that goes on that it should work , it might brake a bit too mush even . dont use a drumbrake master cylinder it will cause the diskbrakes to stay locked the diskbrakes dont have returnsprings like drumbrakes have and rely on the mastercylinder to pul them back in a bit
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
